How can I get my Exim configuration to working with virtualmin?
exim configuration
primary_hostname =
local_interfaces = 0.0.0.0.25 : 0.0.0.0.465 : 0.0.0.0.587
domainlist relay_to_domains =
trusted_users = exim : majordomo
acl_smtp_rcpt = acl_check_rcpt
acl_smtp_data = acl_check_data
av_scanner = clamd:127.0.0.1 3310
spamd_address = 127.0.0.1 783
tls_advertise_hosts = *
tls_certificate = /usr/exim/ca.crt
tls_privatekey = /usr/exim/ca.key
daemon_smtp_ports = 25 : 465 : 587
tls_on_connect_ports = 465
tls_require_ciphers = ALL : !SSLv2 : !LOW : !aNULL : !eNULL : !3DES : @STRENGTH
never_users = root
host_lookup = *
rfc1413_hosts = *
rfc1413_query_timeout = 5s
ignore_bounce_errors_after = 2h
auto_thaw = 1m
message_size_limit = 20M
spool_directory = /var/spool/exim
smtp_receive_timeout = 5m
smtp_accept_max = 25
ACL CONFIGURATION
Specifies access control lists for incoming SMTP mail
begin acl
acl_check_smtp:
accept hosts = :
accept hosts = +relay_hosts
deny hosts = +block_hosts
accept
acl_check_rcpt:
deny message = rejected because $sender_host_address is in a black list at $dnslist_domain\n$dnslist_text
dnslists = sbl-xbl.spamhaus.org : zen.spamhaus.org : dev.null.dk : relays.visi.com : bl.spamcop.net : hostkarma.junkemailfilter.com=127.0.0.2
log_message = found in $dnslist_domain
accept hosts = :
control = dkim_disable_verify
deny message = Restricted characters in address
domains = +local_domains
local_parts = ^[.] : ^.*[@%!/|]
accept local_parts = postmaster
drop message = Legitimate bounces are never sent to more than one recipient.
senders = : postmaster@*
condition = ${if >{$recipients_count}{0}{true}{false}}
accept hosts = +relay_from_hosts
control = submission
accept authenticated = *
control = submission/sender_retain
require message = relay not permitted
domains = +local_domains : +relay_to_domains
require verify = recipient
deny message = Rejected sender
domains = dhl.com
local_parts = adminsu*
domains = .com
local_parts = postmail-
domains = usa.com
local_parts = express.deli*
domains = gmail.com
local_parts = emarketing2*
domains = gmail.com
local_parts = emarketing2sofsol*
domains = gmail.com
local_parts = umair*
domains = gmail.com
local_parts = umairpbl
domains = gmail.com
local_parts = edusa102
domains = doctor.nl2k.ab.ca
local_parts = OWA-Erro*
deny message = Rejected recipient
domains = localhost.com
local_parts = root
deny hosts = /usr/exim/blockhosts
accept
acl_check_data:
##For Port 465
set acl_m_authenticated = 1
accept hosts = :
deny malware = *
message = This message contains a virus ($malware_name).
drop message = This message is denied by policy : $spam_score spam points
spam = nobody:true
condition = ${if > {$spam_score_int}{409}{1}{0}}
warn spam = nobody
message = Subject: {SPAM?} $rh_subject:
add_header = X-Spam_score: $spam_score\n
X-Spam_score_int: $spam_score_int\n
X-Spam_bar: $spam_bar\n
X-Spam_report: $spam_report
#local check for hijacked accounts
deny
!hosts = +relay_from_hosts
message = This message was considered to be spam
spam = www:true
condition = ${if >{$spam_score_int}{409}{1}{0}}
deny senders = /usr/exim/deny_senders
Accept the message.
accept
ROUTERS CONFIGURATION
Specifies how addresses are handled
THE ORDER IN WHICH THE ROUTERS ARE DEFINED IS IMPORTANT!
An address is passed to each router in turn until it is accepted.
begin routers
check_dnslookup:
driver = dnslookup
domains = ! +local_domains
ignore_target_hosts = 0.0.0.0 : 127.0.0.0/8
verify_only
pass_router = amavis
no_more
check_system_aliases:
driver = redirect
allow_fail
allow_defer
data = ${lookup{$local_part}lsearch{/etc/aliases}}
verify_only
check_localuser:
driver = accept
check_local_user
verify_only
virtuals:
driver = redirect
allow_defer
allow_fail
domains = partial-lsearch;/usr/exim/vdom3
data = ${lookup{$local_part@$domain}lsearch*@{/usr/exim/virtualaliases}}
retry_use_local_part
pipe_transport = address_pipe
file_transport = address_file
no_more
dnslookup:
driver = dnslookup
transport = remote_smtp
no_more
system_aliases:
driver = redirect
allow_fail
allow_defer
user = exim
userforward:
driver = redirect
check_local_user
local_part_prefix = +* : -*
local_part_prefix_optional
file = $home/.forward
allow_filter
no_verify
no_expn
check_ancestor
reply_transport = address_reply
localuser:
driver = accept
check_local_user
#local_part_suffix = +* : -*
#local_part_suffix_optional
transport = local_delivery
cannot_route_message = Unknown user
procmail:
driver = accept
check_local_user
require_files = $home/.procmailrc
transport = procmail_pipe
#Majordomo
lists:
driver = redirect
file = /usr/home/majordomo/lists/$local_part
forbid_pipe
forbid_file
errors_to = $local_part-request@nk.ca
user = majordomo
no_more
TRANSPORTS CONFIGURATION
ORDER DOES NOT MATTER
Only one appropriate transport is called for each delivery.
A transport is used only when referenced from a router that successfully
handles an address.
begin transports
This transport is used for delivering messages over SMTP connections.
remote_smtp:
driver = smtp
connect_timeout = 15m
data_timeout = 15m
procmail_pipe:
driver = pipe
command = /usr/bin/procmail -d $local_part
return_path_add
delivery_date_add
envelope_to_add
check_string = "From "
escape_string = ">From "
umask = 077
user = $local_part
group = mail
local_delivery:
driver = appendfile
file = /var/mail/$local_part
delivery_date_add
envelope_to_add
return_path_add
group = mail
mode = 0600
address_pipe:
driver = pipe
return_output
address_file:
driver = appendfile
delivery_date_add
envelope_to_add
return_path_add
address_reply:
driver = autoreply
RETRY CONFIGURATION
begin retry
Address or Domain Error Retries
* F,1h,15m; G,10h,1h,1.5; F,7d,1h
#* data_4xx F,1h,15m; G,2h,30m,1.5; F,3h,10m
#* mail_4xx F,1h,15m; G,2h,30m,1.5; F,3h,10m
#* rcpt_4xx F,1h,15m; G,2h,30m,1.5; F,3h,10m
#* lost_connection F,1h,15m; G,2h,30m,1.5; F,3h,1
0m
#* refused_MX F,1h,15m; G,2h,30m,1.5; F,3h,10m
#* refused_A F,1h,15m; G,2h,30m,1.5; F,3h,10m
#* refused F,1h,15m; G,2h,30m,1.5; F,3h,10m
#* timeout_connect_MX F,1h,15m; G,2h,30m,1.5; F,3h
,10m
#* timeout_connect_A F,1h,15m; G,2h,30m,1.5; F,3h,
10m
#* timeout_connect F,1h,15m; G,2h,30m,1.5; F,3h,10
m
#* timeout_MX F,1h,15m; G,2h,30m,1.5; F,3h,10m
#* timeout_A F,1h,15m; G,2h,30m,1.5; F,3h,10m
#* timeout F,1h,15m; G,2h,30m,1.5; F,3h,10m
127.0.0.1 * F,1h,1m; G,2h,10m,1.5; F,5h,10m
204.209.81.1 * F,1h,1m; G,2h,10m,1.5; F,3h,10m
204.209.81.3 * F,1h,1m; G,2h,10m,1.5; F,5h,10m
#* * F,1h,1m; G,2h,10m,1.5; F,5h,10m
#* * F,1h,2m; G,4h,1h,1.5; F,5h,10m
#* * F,2h,15m; G,16h,1h,1.5; F,4d,6h
REWRITE CONFIGURATION
There are no rewriting specifications in this default configuration file.
begin rewrite
AUTHENTICATION CONFIGURATION
begin authenticators
PLAIN:
driver = plaintext
public_name = PLAIN
server_set_id = $auth2
server_prompts = :
server_condition = ${if saslauthd{{$2}{$3}}{1}{0}}
server_advertise_condition = ${if def:tls_cipher }
LOGIN:
driver = plaintext
public_name = LOGIN
server_set_id = $auth1
server_prompts = <| Username: | Password:
server_condition = ${if saslauthd{{$1}{$2}}{1}{0}}
CONFIGURATION FOR local_scan()
If you have built Exim to include a local_scan() function that contains
tables for private options, you can define those options here. Remember to
uncomment the “begin” line. It is commented by default because it provokes
an error with Exim binaries that are not built with LOCAL_SCAN_HAS_OPTIONS
set in the Local/Makefile.
begin local_scan
End of Exim configuration file
HELP!!
