I read some of the guides that use the old letsencrypt client.
Letsencrypt now recommends using certbot as per https://letsencrypt.org, but certbot seems to be incompatible with Virtualmin as letsencrypt stores cert files in /etc/letsencrypt/live, while Virtualmin stores them under /home/username/…
Anyone successfully using certbot with letsencrypt?
I would not say successfully yet, but I had a couple of domains that wouldn’t auto renew or manually renew with letsencrypt/virtmin. Installed certbot and it worked for those 2 domains the first time. So I’m running certbot manually and manually copying the certs to the folder virtualmin is expecting.
I got certbot to work with certonly update specifying the cert path… Would be nice to have Virtualmin auto do this
