Virtualmain panel has become heavy
Device: iPhone
Browser: Safari
Benchmark time: 3.0 ms
RAM: -1 GB
CPU cores: 4
Slow device: Yes
Thanks @Steini! I’ve fixed the test, so 4 CPU cores shouldn’t be considered slow; only devices with fewer than 4 cores should be. So, in your case, it should say ā€œNoā€ for ā€œSlow deviceā€ column.
Benchmark time: 33.0 ms
RAM: 4 GB
CPU cores: 8
Slow device: No
Test on Samsung J8 with Chrome browser.
Benchmark time: 65.0 ms
RAM: -1 GB
CPU cores: 8
Slow device: Yes
Test on Samsung J8 with Firefox browser.
Thanks! But do not do Firefox browser, try Chrome or Edge.
Wait, can you run this instead?
https://virtualmin.dev/benchmark.html
Device: SM-J810F
Browser: Chrome
Benchmark time: 42.2 ms
RAM: 4 GB
CPU cores: 8
Slow device: No
Device: MAR-LX1M
Browser: Chrome
Benchmark time: 33.9 ms
RAM: 4 GB
CPU cores: 8
Slow device: No
Tested with another phone.
Look, that’s confusing—I’m not sure how to handle it. Just out of curiosity, what Android version do you have installed?
The only best solution for you is to create a separate Webmin user for mobile use with live stats disabled.
Android version: Android 10 (One UI 2.0)
Thanks so much, Ilia — I truly appreciate the time and attention you’re giving to this issue.
Your suggestion to create a dedicated Webmin user for access on low-end devices, with real-time monitoring disabled, is a very smart and elegant workaround. It effectively solves the performance problems on lower-end devices and is a great solution for now.
Also, the benchmark test idea was helpful — the results can still give a general sense of a device’s capability (for example, a delay below 20 ms on a device with at least 4 CPU cores may suggest a reasonably powerful system). But overall, I understand and agree with your point that a proper solution requires broader and more context-aware logic.
I really don’t like this benchmark idea. That’s abusing user resources and chomping up battery life.
Just default to not doing heavy stuff on a small screen…hide those graphs behind a button or whatever and the user has to explicitly choose to load a realtime stats page, instead of having to pay the price always.
Yeah, sure thing, I wasn’t going to add this. Though, it’s not resourceful or abusive in any way. It’s just unreliable.
I’m not sure if we should, since it seems to be a one-user issue. In that case, the solution is to create a separate Webmin user login with different settings for a low-spec mobile device.
Have you added a swap disk? It can make huge difference on a low RAM system.
I have 1gb swap disk, which I thought would have been enough, but as this is a different problem to the original one I may open a new thread at some point
Well thought I would give it a try.
no idea why but all I get is a blank screen that eventually seems to redirect to virtualmin/docs, hey but as I said, it is an old J8 with most things blocked (over the years) no idea what android version is running. it only is used for sms and as a ā€œbrickā€ phone only a couple of apps
Device: Unknown device
Browser: Chrome
Benchmark time: 5.8 ms
RAM: 8 GB
CPU cores: 4
Slow device: No
Device: SM-S928U
Browser: Chrome
Benchmark time: 15.9 ms
RAM: 8 GB
CPU cores: 8
Slow device: No
Thanks for sharing! We won’t use this approach to solve the problem.
The most likely solution is not to send data over the socket in mobile mode unless a user is on the dashboard or has a large enough mobile screen for the right-side slider to stay fixed. Data from the socket updates it too—did y’all know that? :slight_smile:
…after checking the code, there’s room for improvement. I originally made it simple, pausing socket communication if the page isn’t visible or not focused. If we didn’t need to constantly update the right-side slider, which is functioning as a small, always-available dashboard then we could just open the socket when the user visits the main dashboard and close it afterward. But since we need to update the slider, it’s not an option.
I’ll try to fix it as described and will update this ticket with the progress…
This feature has been implemented! From now on, we won’t send any data over the socket a few seconds after the dashboard page is left or the right side slider is closed. We’ll also pause socket communication if the page isn’t focused.
@asadister Give it a try with the latest Webmin development version, and let us know how it goes for you.
Hi Ilia,
I just tested the latest development version of Webmin (2.402-dev) on my server with real-time monitoring enabled.
It’s behaving erratically now, sometimes smooth and sometimes slow, this is most noticeable when opening menus.
If there’s anything else I should test, let me know.
Thanks!
The theme behaves predictably. It’s in fact as accurate as it can be.
I’m not sure what you mean by ā€œmenusā€. Though keep in mind that socket communication resumes when:
  1. The dashboard is visited
  2. The right side slider is opened
After you leave the dashboard page or close the right side slider, the system waits about 5 seconds before pausing socket communication.
If you want to test if socket communication affects performance on your low specs phone, avoid opening the right side slider or dashboard, and then navigate through the pages of Virtualmin or Webmin.
Remember that by default, when you switch between Virtualmin and Webmin, the dashboard opens, which restarts socket communication.
Simply put, socket communication restarts in about 300 milliseconds after visiting the dashboard or opening the right side slider and takes about 5 seconds to pause again after they’re closed.
