I have a number of sites on this server, all seem fine, except I added a new vmin server rhodymail.com, went smoothly, then I did lets encrypt and SSL…when I preview the site, it shows fine, but when I go to view it on the web, it either brings up a white page with several small aaaaa’s on it or the index page of another site on the server (amazingri.com). It also doesn’t use ssl.
When you created the virtual server, did you enable the SSL website feature? The box is most likely not checked and SSL has not been enabled for the domain.
If so, the issue is easy to fix. Just Edit Virtual Server and enable SSL website for this virtual server.
