Virtual IP interface
Hi there
I am running virtualmin GPL and only have 1 dedicated external IP address at this time. I am in the process of ordering a new line for my second ip address.
I have everything working fine as it should however I have come across a problem I already have my own ssl certificate for my domain however I need to include another ssl certificate for another domain.
When I create the virtual server with ssl it states I already have a ssl for this domain I can continue but browsers may see the present certificate before the new one if I click create it creates the host I can see the site from outside my lan.
I am behind a router with a default ip of 192.168.1.67 this is static as set in etc/network/interfaces.
I tried to create a virtual IP address by setting the range is the virtual IP range settings. When I then create a host and select virtual with ip it creates the domain and give no errors.
If I then type the domain name into browser it defaults to the default website address on my server.
It created the ip address 192.168.1.102 if I type this into url site appears bit not from outside world.
did I miss something with regards to virtual IP address settings.
I’m aware I could use multi ssl validation things but it’s expensive compared to single ssl certs any work around or diagnostics to help me find the problem.
