I’m having some issues getting virtual interfaces to work.
I’ve set up my virtual server to use an IP from the pool i specified in the server template.
As far as I can see it add everything like it should be. But I am no guru at virtual interfaces. Actually I’ve never done it before.
Here are some of my settings:
Network interface for virtual addresses = eth0
Default virtual server IP address = From network interface
Default IP address for DNS records = Automatically detect external address
The virtual interface gets put up as eth0:1 and the ip from my range is 192.168.122.2
Some insight would be greatly appreciated.
EDIT:
I forgot to mention that all traffic to the new virtual interface is sendt directly to the site hosted at the hostname of the server.<br><br>Post edited by: olafskaug, at: 2009/04/03 04:21
As ronald mentioned, you’re probably going to a lot of trouble for nothing. Unless you have a public IP per private IP, and you’re forwarding each of them to a different private address, there is nothing useful you can do with a bunch of private IPs.
I thought the whole point of the virtual ip’s was that you could have many ssl certs. I’m at a point where i need to have more than one. Will I have to create a multi domain ssl cert?
