I just installed virtualmin and am trying to setup virtual domains. Virtualmin is not setup however it wants to check configuration. when I run the "refresh and check configuration" it says my system is not ready
"no virtual domains file was found in your postfix configuration. Maybe no virtual domain map has been defined"
I very new and cannot figure out what to do to fix this. please help
Browse to the Postfix module in Webmin, click on Virtual Domains. In the field labeled "Domain mapping lookup tables" set the radio button to the text field and fill in "hash:/etc/postfix/virtual". Save it, and restart postfix.
That said, I strongly recommend using our automated install script if you are using a supported platform (CentOS 5 or Debian 4.0). Setting things up manually can be very time consuming, and most newbies are quite intimidated by the "rebuild Apache with suexec docroot set to /home" step.
