Is it possible to install Virtualmin GPL on a machine and have it manage web sites in Apache, but leave the existing email system entirely untouched? I have a slightly intricate Postfix-based email system that I want to continue using exactly as it is.
Thanks for your suggestion. How will it prevent Virtualmin, in normal operation, from trying to edit the Postfix configuration files? Would you please confirm that you have sound reasons for believing that it will work? Thank-you.
During installation, the install.sh script touches Postfix’s /etc/postfix/main.cf file. By not running the install.sh script, Virtualmin won’t touch that file unless you otherwise tell it to do so.
Once Virtualmin is installed, email users will be added to /etc/postfix/virtual, and in some cases, entries added to /etc/aliases.
But, that won’t occur if you disable the “Mail” feature.
To do that, go into System Settings -> Features and Plugins, and make sure “Mail for domain”, “Spam Filtering”, and “Virus Filtering” are all disabled before you add any Virtual Servers.
However, there’s no substitute for good 'ol fashioned testing
If you’re concerned about how Virtualmin will affect your system, I’d recommend setting it up on a test server before trying anything on a live system.
