I have two sets of sites on my server. My normal Apache sites and a number of docker sites. I use HAProxy to direct traffic to the Docker containers if the domain matches, otherwise it sends all other traffic to my normal Virtualmin Apache.
All that works fine, but now I want to use https on my docker sites. My current config seems to work fine with my normal virtualmin apache sites (which I have set Virtulamin/Apache to listen on port 8080) but I can’t seem to get HTTPS working. Here is my HAProxy config:
global
# to have these messages end up in /var/log/haproxy.log you will
# need to:
# 1) configure syslog to accept network log events. This is done
# by adding the '-r' option to the SYSLOGD_OPTIONS in
# /etc/sysconfig/syslog
# 2) configure local2 events to go to the /var/log/haproxy.log
# file. A line like the following can be added to
# local2.* /var/log/haproxy.log
# log 127.0.0.1 local2
# chroot /var/lib/haproxy
pidfile /var/run/haproxy.pid
maxconn 4000
user haproxy
group haproxy
daemon
# turn on stats unix socket
stats socket /var/lib/haproxy/stats
defaults
mode http
log global
option httplog
option dontlognull
option http-server-close
# option forwardfor except 127.0.0.0/8
option forwardfor
option redispatch
retries 3
timeout http-request 10s
timeout queue 1m
timeout connect 10s
timeout client 1m
timeout server 1m
timeout http-keep-alive 10s
timeout check 10s
maxconn 3000
frontend http-in
bind *:80
default_backend main_apache_sites
# Define hosts
redirect prefix http://discourse-forum-1.com code 301 if { hdr(host) -i www.discourse-forum-1.com }
acl host_discourse hdr(host) -i discourse-forum-1.com
redirect prefix http://discourse-forum-2.com code 301 if { hdr(host) -i www.discourse-forum-2.com }
acl host_discourse_2 hdr(host) -i discourse-forum-2.com
redirect prefix http://discourse-forum-3.com code 301 if { hdr(host) -i www.discourse-forum-3.com }
acl host_discourse_3 hdr(host) -i discourse-forum-3.com
# which one to use
use_backend discourse_docker if host_discourse
use_backend discourse_docker_2 if host_discourse_2
use_backend discourse_docker_3 if host_discourse_3
server server1 127.0.0.1:8080 cookie A check
cookie JSESSIONID prefix nocache
server server2 127.0.0.1:8888 cookie A check
server server2 127.0.0.1:8889 cookie A check
server server2 127.0.0.1:8890 cookie A check
cookie JSESSIONID prefix no cache
Anyone have any ideas on how I can get https for my docker sites?
