Using contabo S3 storage in virtualmin (ubunu 22 vps)
OS type and version Ubuntu 22
Webmin version 2.202
Virtualmin version 7.20.2
Webserver version Apache version 2.4.52
I cannot get S3 contabo provider working.
If i do ''add new s3 account"
And fill in the necessary access key and secret key for eu2.contabostorage.com everything goes fine.
I can get a list of buckets, which is correct, but if i want to add a new bucket i get
Can’t locate object method “new” via package “S3::AWSAuthConnection” (perhaps you forgot to load “S3::AWSAuthConnection”?) at /usr/share/webmin/virtual-server/s3-lib.pl line 1005.
If i try to open an excisting bucket i get:
Error — Perl execution failed
Can anyone help me to solve this ?
Known bug:
Thanks for the answer. I understand it will be fixed in the next release.
(btw, i searched on github but did not find that one)
Make sure to also include is:closed in the filter to search the closed issues too :slight_smile:
You mean this
