Using a non-registered domain
Hello
I’m working on a new version of a website that is currently owned by another provider. DNS still point to old provider.
I will transfer DNS to my newly created site once it is ready.
Is there a way to create (and working to) a virtual server that is not currently pointed by a DNS?
I mean something like: http://123.123.123.123/~mynewsite
Thank you.
It sounds like you may want to try one of the suggestions mentioned in the section “How do I make domains available before the DNS changes are made at the registrar” here:
http://www.virtualmin.com/documentation/web/faq
Let us know if that does the trick!
Solved!
Now I discovered how creating web aliases.
THANK YOU for your unvaluable help
Cheers!
-Carlo
