Uservoices for Virtualmin/Usermin/Webmin/Cloudmin
I have always like the uservoices style of user suggestions where people can vote up stuff they want.
I find this helps user engagement and allows the non-programmer to put a vote on something they want. Not everyone does GitHub issues (I should know, lol) and also this stops a suggestion getting lost on an old forum thread.
This is almost free market research :smile:
This could replace the blueskies section on the forum.
You could give Pro users more points to vote with.
I am sure there are opensource versions of uservoices out there, I could look around if you guys are interested.
see poll below
Let’s Have a vote on it
  • Yes
  • No
0 voters
Replace - No - Added to each Blue Sky/Suggestion(Site Feedback) - Yes
(never heard of ā€œuservoicesā€ - and refuse/actively avoid to use Git)
A former employer used to operate PHPBack - but this ship looks abandoned meanwhile (but still works, though I won’t recommend deploying on a prod environment).
An interesting contender seems to be Fider:
An open source project that integrates with Virtualmin is TikiWiki - tiki.org
It would be quite trivial to use Tiki to create such web apps very quickly for use by the Virtualmin community via Tiki’s low code syntax.
What is wrong for the staff to use discourse polls ? If this was added there is no work for staff and tbf dead simple to add. Why do you need a third party?
these discourse polls are silo’ed and cannot be compared at a glance against others discource polls.
If you use a uservoices then you can see which feature request is most popular, how many people want this and also users can move their votes about if they change there mind.
The fact that there is an easy to read leader board is great.
This site is ā€œuservoicesā€. The problem isn’t user input per se but the number of users that regularly use this site. The software works well enough that most users either NEVER come here or VERY RARELY come here. The voices here are indicative, but not necessarily representative, of the installed user base.
If the staff feels an idea has merit, it won’t end up forgotten in some old thread. If it does, maybe that’s because that’s where it belongs? :wink:
And I have helped, I like to think a lot, with this :smile: , so I see this from a different point of view.
This uservoices (or whatever) is for new features, not reporting bugs.
But this if it goes to a third party to validate the input data this puts an extra amount of work for the user, this may be fine in a desktop environment but as I use a mobile phone for this, I hate running off site to input data so normally ignore links like that
There will developer notes and if you are not happy with the product, just don’t install it. That’s what dev sites are for.
I also addressed this in my first post with the tags I proposed.
I also am not intending these to be available in the Webmin/Virtualmin repos unless they are fully approved and this is what the team want.
A modern cataglogue will help user engaugement and help push webmin/virtualmin/cloudmin forwards above a lot of the other smaller cpanels.
I’m missing the point then, I thought you ment it was to be added to this site rather some addon for either webmin or virtualmin products. If you mean an addon for the install I would forget it
I like the gist of the idea, but I don’t want to use some third-party service. I don’t like data silos out of our control.
But, I found a plugin for Discourse that seems to do what we’d need. Discourse Post Voting - plugin - Discourse Meta
With that, we could make a category for feature voting, and then every post can be voted on (like reddit) and it could be sorted by Top, so the ā€œbestā€ idea rises to the top. I think there’s probably more stuff needing to be sorted out, but maybe this weekend I’ll see about installing it on our dev instance and tinker with it if I can find some time.
You need to keep the discussions in separate threads, otherwise this gets messy fast. 2-way links? Might not be bad if you can get community support to keep them up.
Oh, you’re right. I thought that was about topics being votable within a category, but on second look it seems to be about replies within a topic. I guess I’ll keep looking…
Ah, this is what I actually wanted, I think. Discourse Topic Voting - plugin - Discourse Meta
Just to be clear, I don’t either, and I was aiming at a piece of software being installed and controlled at Virtualmin HQ.
this is an example for people to look at for the sort of thing I would like
https://feedback.uservoice.com/forums/1-general-feedback
Have a look at Plans and Pricing | UserVoice looks like we might need a gofundme page :slight_smile:
Read the thread please. No where do I say use uservoices.
Bar the title
