Fresh install latest gpl virtualmin webmin theme centos 7
MAILDIR/sent dropdown not working or not seeing mails sent out of WEBMIN > read usermail >composed and .sent
Webmin version 1.900
Usermin version 1.751
Virtualmin version 6.06
Operating system CentOS Linux 7.6.1810
Perl version 5.016003
Path to Perl /usr/bin/perl
BIND version 9.9
Postfix version 2.10.1
Mail injection command /usr/lib/sendmail -t
Apache version 2.4.6
PHP versions 5.4.16, 7.0.27
Webalizer version 2.23-08
Logrotate version 3.8.6
MySQL version 5.5.60-MariaDB
ProFTPD version 1.35
SpamAssassin version 3.4.0
ClamAV version 0.101.2
Use of uninitialized value in numeric ge (>=) at /usr/libexec/usermin/mailbox/index.cgi line 86.
Use of uninitialized value $mailbox::in{"folder"} in concatenation (.) or string at /usr/libexec/usermin/mailbox/index.cgi line 378.
Use of uninitialized value in addition (+) at /usr/libexec/usermin/mailbox/index.cgi line 381.
Use of uninitialized value in addition (+) at /usr/libexec/usermin/mailbox/index.cgi line 385.
Use of uninitialized value in subtraction (-) at /usr/libexec/usermin/mailbox/index.cgi line 387.
Use of uninitialized value in subtraction (-) at /usr/libexec/usermin/mailbox/index.cgi line 388.
Use of uninitialized value $mailbox::in{"start"} in int at /usr/libexec/usermin/mailbox/index.cgi line 106.
Use of uninitialized value in addition (+) at /usr/libexec/usermin/mailbox/index.cgi line 107.
Use of uninitialized value in split at /usr/libexec/usermin/mailbox/mailbox-lib.pl line 600.
Use of uninitialized value $mailbox::user_module_config_directory in concatenation (.) or string at ./mailbox-lib.pl line 30.
Use of uninitialized value $mailbox::user_module_config_directory in concatenation (.) or string at ./mailbox-lib.pl line 31.
Use of uninitialized value in concatenation (.) or string at ./mailbox-lib.pl line 32.
Use of uninitialized value $mailbox::user_module_config_directory in concatenation (.) or string at ./mailbox-lib.pl line 37.
Use of uninitialized value $mailbox::user_module_config_directory in concatenation (.) or string at ./mailbox-lib.pl line 38.
Use of uninitialized value $mailbox::user_module_config_directory in concatenation (.) or string at ./mailbox-lib.pl line 1479.
Use of uninitialized value $mailbox::user_module_config_directory in concatenation (.) or string at ./mailbox-lib.pl line 1484.
Use of uninitialized value $mailbox::user_module_config_directory in opendir at ./mailbox-lib.pl line 257.
readdir() attempted on invalid dirhandle DIR at ./mailbox-lib.pl line 258.
closedir() attempted on invalid dirhandle DIR at ./mailbox-lib.pl line 259.
Use of uninitialized value $mailbox::userconfig{"mailbox_dir"} in string eq at ./mailbox-lib.pl line 485.
Use of uninitialized value $mailbox::userconfig{"mailbox_dir"} in string eq at ./mailbox-lib.pl line 491.
Use of uninitialized value $mailbox::userconfig{"mailbox_dir"} in string eq at ./mailbox-lib.pl line 509.
Use of uninitialized value $mailbox::userconfig{"mailbox_dir"} in string eq at ./mailbox-lib.pl line 516.
Use of uninitialized value $mailbox::userconfig{"mailbox_dir"} in string eq at ./mailbox-lib.pl line 531.
Use of uninitialized value $mailbox::userconfig{"mailbox_dir"} in string eq at ./mailbox-lib.pl line 538.
Use of uninitialized value $mailbox::userconfig{"mailbox_dir"} in string ne at ./mailbox-lib.pl line 578.
Use of uninitialized value in split at ./mailbox-lib.pl line 600.
Use of uninitialized value $mailbox::userconfig{"folder_sort"} in numeric eq (==) at ./mailbox-lib.pl line 1235.
Use of uninitialized value in numeric eq (==) at /usr/libexec/usermin/mailbox/index.cgi line 29.
Use of uninitialized value $mailbox::in{"jump"} in pattern match (m//) at /usr/libexec/usermin/mailbox/index.cgi line 77.
Use of uninitialized value $mailbox::in{"start"} in int at /usr/libexec/usermin/mailbox/index.cgi line 83.
Use of uninitialized value $mailbox::user_module_config_directory in concatenation (.) or string at ./mailbox-lib.pl line 1992.
Use of uninitialized value $mailbox::config{"server_name"} in string eq at /usr/libexec/usermin/mailbox/mailbox-lib.pl line 1324.
readline() on closed filehandle $ADDRESS at /usr/libexec/usermin/mailbox/mailbox-lib.pl line 166.
Use of uninitialized value within %read in int at /usr/libexec/usermin/mailbox/mailbox-lib.pl line 1555.
Use of uninitialized value in concatenation (.) or string at ./mailbox-lib.pl line 1295.
Use of uninitialized value $mailbox::config{"server_name"} in string eq at ./mailbox-lib.pl line 1324.
readline() on closed filehandle $ADDRESS at ./mailbox-lib.pl line 166.
Use of uninitialized value $wm in substitution (s///) at /usr/libexec/usermin/mailbox/reply_mail.cgi line 825.
Use of uninitialized value in concatenation (.) or string at /usr/libexec/usermin/mailbox/reply_mail.cgi line 844.
Use of uninitialized value $subs in concatenation (.) or string at /usr/libexec/usermin/mailbox/reply_mail.cgi line 844.
Use of uninitialized value in concatenation (.) or string at /usr/libexec/usermin/mailbox/reply_mail.cgi line 846.
Use of uninitialized value $subs in concatenation (.) or string at /usr/libexec/usermin/mailbox/reply_mail.cgi line 846.
Use of uninitialized value $subs in concatenation (.) or string at /usr/libexec/usermin/mailbox/reply_mail.cgi line 848.
Use of uninitialized value in concatenation (.) or string at /usr/libexec/usermin/mailbox/reply_mail.cgi line 883.
Use of uninitialized value $mailbox::userconfig{"ham_buttons"} in pattern match (m//) at ./mailbox-lib.pl line 1784.
Use of uninitialized value within %read in int at ./mailbox-lib.pl line 1555.
Use of uninitialized value $sortfield in string eq at ./mailbox-lib.pl line 2013.
Use of uninitialized value $sortfield in string eq at ./mailbox-lib.pl line 2014.
Use of uninitialized value in concatenation (.) or string at ./mailbox-lib.pl line 2018.
Use of uninitialized value $qstart in concatenation (.) or string at ./mailbox-lib.pl line 2031.
Use of uninitialized value in split at /usr/libexec/usermin/mailbox/view_mail.cgi line 25.
print() on unopened filehandle DEBUG at ./mailbox-lib.pl line 1572.
Use of uninitialized value $mailbox::in{"body"} in numeric eq (==) at /usr/libexec/usermin/mailbox/view_mail.cgi line 122.
Use of uninitialized value $mailbox::in{"body"} in numeric eq (==) at /usr/libexec/usermin/mailbox/view_mail.cgi line 123.
Use of uninitialized value $htmlbody in string eq at /usr/libexec/usermin/mailbox/view_mail.cgi line 127.
Use of uninitialized value in concatenation (.) or string at /usr/libexec/usermin/mailbox/view_mail.cgi line 184.
Use of uninitialized value in concatenation (.) or string at /usr/libexec/usermin/mailbox/view_mail.cgi line 186.
