Is there away to set Usermin to use only HTML to view mail, or at least switch the default from Test to HTML so its set automatically for all users?
Yup, you can do that!
If you go into Webmin -> Webmin -> Usermin Configuration -> Usermin Module Configuration -> Read Mail -> Default user preferences, you can change the defaults used on that screen.
Got it! I guess my issue is its far to easy to over look additional tabs and features in Virtualmin…everything blends in together and its often difficult to find what your looking for because they are overlooked when navigating.
I have to really pay closer attention to the small details.
