Usermin Reply Window is very small, can it use
Then perhaps you should also remove Terminal from the menu as it is also an icon at the bottom.
It’s not the extension buttons, they are obvious once you get to Theme Config - which is what I suggest should also be a Menu item.
It’s not normal for me to look everywhere but the menu for something I haven’t used before, or have forgotten if I have used it.
Just sharing my own experience.
The menu option & the icon do 2 different things, The menu option produces a ‘windowed’ terminal whereas the icon produces a full page overlay, which would be the best to remove ?
We have it searchable in the menu too though:
That’s a different type of terminal; it’s a drop-down terminal that you can also open with ⌥ K or Alt + K.
I wouldn’t look; I’d just use auto-complete suggestions to search. Who even looks through everything when you can just start typing (or hit / first) to find what you need?
Yes, I found that but when I click on any of the options nothing happens.
Maybe it’s not supposed to? (should that be mentioned too, or just another dimwit error by me?)
But it still doesn’t say “This one isn’t a menu option - it’s an icon only outlier”
Anyway, you are the good people that do all the work and the design and like it that way.
That’s a very sporadic bug. I saw it happen only a few times, and I couldn’t reproduce it to fix it. It’s easier to just use the keyboard arrow and enter key to go to search results.
Yeah, I know, but I don’t think it deserves a whole separate link that takes up space on the menu.
Thanks!
Theme Configuration could be added to Webmin > Webmin Configuration > Webmin Themes alongside Change, Install, Delete and Export themes.
Take no extra space and is then findable.
Yes, it will be fixed in the Authentic 26.00 release shortly!
