When I successfully login to Usermin (port :20000) and then Usermin -> Mail -> Read Mail I got an error “An error occurred listing mail in this folder : Failed to connect to localhost:143 : Connection refused” and it’s the same for every other account (root, admin domains, user domains).
When I’m using email with programs like Windows Mail (Vista), everything works fine (incoming/outcoming).
I’ve check /var/log/mail.log and /var/log/dovecot.log and there is nothing about that error, even no connection log when trying to connect by Usermin interface.
Well, normally I’d suggest making sure that Dovecot is running – but I suspect it will be if it works from other clients.
I’d be curious if anything at all shows up in /var/log/auth.log and /var/log/mail.log when you’re attempting to connect. It might have a completely different error than what you’re seeing in Usermin.
As a complete shot in the dark, it’s possible that “disable_plaintext_auth = no” needs to be set in your /etc/dovecot/dovecot.conf. If you try that, be sure to restart Dovecot afterwards.
Well, normally I'd suggest making sure that Dovecot is running -- but I suspect it will be if it works from other clients.
Dovecot is running.
I'd be curious if anything at all shows up in /var/log/auth.log and /var/log/mail.log when you're attempting to connect. It might have a completely different error than what you're seeing in Usermin.
There is nothing about that connection I'm trying to make through Usermin.
As a complete shot in the dark, it's possible that "disable_plaintext_auth = no" needs to be set in your /etc/dovecot/dovecot.conf. If you try that, be sure to restart Dovecot afterwards.
However i had migrated from a 10.04to 12.04 after the install of virtualmin, I am not sure if it was cause I didn’t reboot after the install. whippy’s remedy worked for me as well.
However i had migrated from a 10.04 to 12.04 after the install of virtualmin, I am not sure if it was cause I didn’t reboot after the install. whippy’s remedy worked for me as well.
