Usermin "move" function directing emails inaccurately
A client just complained that using UserMin, he was trying to move emails to a specific folder, but the mails were being moved to a different folder.
I was able to recreate the error, and it seemed that the email was being moved to the folder immediately after the one that was targeted.
I was able to successfully move folders accurately in Thunderbird client on a local PC, but the problem persisted in Usermin.
I am unable to recreate the error in other virtual servers, but can recreate the behaviour in the same domain as the original user.
I have deleted the user after saving the emails on Thunderbird, recreated the mailbox, and replaced the emails. The problem still persists.
I have looked online to try to find a similar issue, but haven’t been able to find anything. Consequently I fear that this is not a common problem.
Anyone have any ideas on how I could overcome the problem?
OS type and version 2.302
Webmin version 2.402
Virtualmin version 7.30.8 Pro
Webserver version Apache version 2.4.62
Usermin . 2.302
What are the folders? User created or the system defaults? I’m assuming that Thunderbird recreated the folders from scratch when you restored?
Seeing your pro maybe log a ticket and one of the staff can look at it.
I too have noticed this bug.
Does it happen if you switch to the old Framed Theme instead of Authentic in Usermin? That sounds kinda like some sort of UI off-by-one bug…It could be in the backend, as well, but worth a try. That would tell us who would be the one to fix it, Ilia or Jamie.
Idea:-) Will do that
