Usermin is not loading since 1 hour or long
I go to my ip and port, in it the mail inbox is not opening, everything else can be opened easily only the problem with my empty mail inbox
**Also I cannot be able to click on New Message button, it is not clickable at my side**
I would recommend you use the hostname of one of your Virtualmin domains to connect to Usermin (and Webmin). That gets you an https connection with a valid TLS cert.
You’ll probably want to look at the Web Developer tools in your browser to see what is happening. Maybe a JavaScript or network error.
If nothing is happening in the browser, you might check the Usermin miniserv.error log in /var/usermin. Though I kinda doubt this will be a server-side issue.
Showing 302 error Moved temporary
Also No such directory error
Usermin is misconfigured. How’d you install it?
This is a Virtualmin system right? It would normally setup Usermin for mail in Maildir or via IMAP (I don’t remember which), not a mail spool like that.
I just install Virtual Min and use usermin but this problem occured
yes, but the key question is HOW? and was it a clean OS?
there are some pretty useless instructions out there in the wild - not to mention some OS provided by 3rd parties that are not clean
And avoid images of serves which have Virtualmin / Webmin pre-installed. These are offered by some cloud service providers but they don’t do it right.
The question that everyone is asking you, @HarshVardhanSolanki, is this: did you use the Virtualmin Automated Installer or not?
