OS type and version
Rocky 8 and 9
Virtualmin version
7.7
I’ve tried several times with fresh installs of the latest Rocky 8 and Rocky 9, and experience the same problems. I get the following error during the installation after configuring Fail2BanFirewall:
Use of uninitialized value $backend in concatenation (.) or string at /usr/share/perl5/vendor_perl/Virtualmin/Config/Plugin/Fail2banFirewalld.pm line 90.
After setting up a domain and a user, I get authentication failures when trying to log in via IMAP or SMTP AUTH. If I try logging in to Usermin, the password works, but fails when trying to display the inbox with an IMAP authentication error.
Joe
July 6, 2023, 4:17pm
2
swimboy:
These two things are unrelated.
The Fail2banFirewalld error is a known issue and will be fixed in a virtualmin-config update. It is a cosmetic issue.
We need to see the maillog
(or journal for the relevant service) entries when you try to authenticate with IMAP or SMTP.
OK, I was able to resolve the IMAP authentication issue, but still can’t get SMTP AUTH to work. Here are the relevant log entries:
/var/log/maillog:
Jul 7 13:22:39 localhost postfix/smtpd[104251]: warning: SASL authentication failure: Password verification failed
Jul 7 13:22:39 localhost postfix/smtpd[104251]: warning: d4-50-154-112.nap.wideopenwest.com[50.4.112.154]: SASL PLAIN authentication failed: authentication failure
Jul 7 13:22:41 localhost postfix/smtpd[104251]: warning: SASL authentication failure: Password verification failed
Jul 7 13:22:41 localhost postfix/smtpd[104251]: warning: d4-50-154-112.nap.wideopenwest.com[50.4.112.154]: SASL PLAIN authentication failed: authentication failure
Jul 7 13:22:43 localhost postfix/smtpd[104251]: warning: d4-50-154-112.nap.wideopenwest.com[50.4.112.154]: SASL LOGIN authentication failed: authentication failure
Jul 7 13:22:45 localhost postfix/smtpd[104251]: warning: d4-50-154-112.nap.wideopenwest.com[50.4.112.154]: SASL LOGIN authentication failed: authentication failure
Jul 7 13:22:45 localhost postfix/smtpd[104251]: disconnect from d4-50-154-112.nap.wideopenwest.com[50.4.112.154] ehlo=2 starttls=1 auth=0/4 quit=1 commands=4/8
Jul 7 13:25:34 localhost postfix/anvil[99750]: statistics: max connection rate 2/60s for (submission:50.4.112.154) at Jul 7 13:18:22
Jul 7 13:25:34 localhost postfix/anvil[99750]: statistics: max connection count 1 for (submission:50.4.112.154) at Jul 7 13:15:34
Jul 7 13:25:34 localhost postfix/anvil[99750]: statistics: max cache size 2 at Jul 7 13:20:16
and /var/log/secure:
Jul 7 13:22:37 localhost saslauthd[20261]: pam_unix(smtp:auth): check pass; user unknown
Jul 7 13:22:37 localhost saslauthd[20261]: pam_unix(smtp:auth): authentication failure; logname= uid=0 euid=0 tty= ruser= rhost=
Jul 7 13:22:39 localhost saslauthd[20263]: pam_unix(smtp:auth): check pass; user unknown
Jul 7 13:22:39 localhost saslauthd[20263]: pam_unix(smtp:auth): authentication failure; logname= uid=0 euid=0 tty= ruser= rhost=
Jul 7 13:22:41 localhost saslauthd[20264]: pam_unix(smtp:auth): check pass; user unknown
Jul 7 13:22:41 localhost saslauthd[20264]: pam_unix(smtp:auth): authentication failure; logname= uid=0 euid=0 tty= ruser= rhost=
Jul 7 13:22:44 localhost saslauthd[20265]: pam_unix(smtp:auth): check pass; user unknown
Jul 7 13:22:44 localhost saslauthd[20265]: pam_unix(smtp:auth): authentication failure; logname= uid=0 euid=0 tty= ruser= rhost=
and here’s the SMTP trace from the client:
INITIATING CONNECTION Jul 07 09:22:36.515 host:hawk.tagcomp.com -- port:587 -- socket:0x0 -- thread:0x6000003e4400
CONNECTED Jul 07 09:22:36.553 [kCFStreamSocketSecurityLevelNone] -- host:hawk.tagcomp.com -- port:587 -- socket:0x600003c366a0 -- thread:0x6000003e4400
READ Jul 07 09:22:36.604 [kCFStreamSocketSecurityLevelNone] -- host:hawk.tagcomp.com -- port:587 -- socket:0x600003c366a0 -- thread:0x6000003e4400
220 hawk.tagcomp.com ESMTP Postfix
WROTE Jul 07 09:22:36.604 [kCFStreamSocketSecurityLevelNone] -- host:hawk.tagcomp.com -- port:587 -- socket:0x600003c366a0 -- thread:0x6000003e4400
EHLO smtpclient.apple
READ Jul 07 09:22:36.645 [kCFStreamSocketSecurityLevelNone] -- host:hawk.tagcomp.com -- port:587 -- socket:0x600003c366a0 -- thread:0x6000003e4400
250-hawk.tagcomp.com
250-PIPELINING
250-SIZE 10240000
250-VRFY
250-ETRN
250-STARTTLS
250-AUTH PLAIN LOGIN
250-AUTH=PLAIN LOGIN
250-ENHANCEDSTATUSCODES
250-8BITMIME
250-DSN
250-SMTPUTF8
250 CHUNKING
WROTE Jul 07 09:22:36.645 [kCFStreamSocketSecurityLevelNone] -- host:hawk.tagcomp.com -- port:587 -- socket:0x600003c366a0 -- thread:0x6000003e4400
STARTTLS
READ Jul 07 09:22:36.680 [kCFStreamSocketSecurityLevelNone] -- host:hawk.tagcomp.com -- port:587 -- socket:0x600003c366a0 -- thread:0x6000003e4400
220 2.0.0 Ready to start TLS
WROTE Jul 07 09:22:36.870 [kCFStreamSocketSecurityLevelTLSv1_2] -- host:hawk.tagcomp.com -- port:587 -- socket:0x600003c366a0 -- thread:0x6000003e4400
READ Jul 07 09:22:36.914 [kCFStreamSocketSecurityLevelTLSv1_2] -- host:hawk.tagcomp.com -- port:587 -- socket:0x600003c366a0 -- thread:0x6000003e4400
250-PIPELINING
250-SIZE 10240000
250-VRFY
250-ETRN
250-8BITMIME
250-DSN
250-SMTPUTF8
250 CHUNKING
WROTE Jul 07 09:22:36.915 [kCFStreamSocketSecurityLevelTLSv1_2] -- host:hawk.tagcomp.com -- port:587 -- socket:0x600003c366a0 -- thread:0x6000003e4400
AUTH PLAIN (*** 56 bytes hidden ***)
READ Jul 07 09:22:39.163 [kCFStreamSocketSecurityLevelTLSv1_2] -- host:hawk.tagcomp.com -- port:587 -- socket:0x600003c366a0 -- thread:0x6000003e4400
535 5.7.8 Error: authentication failed: authentication failure
WROTE Jul 07 09:22:39.163 [kCFStreamSocketSecurityLevelTLSv1_2] -- host:hawk.tagcomp.com -- port:587 -- socket:0x600003c366a0 -- thread:0x6000003e4400
AUTH PLAIN (*** 36 bytes hidden ***)
READ Jul 07 09:22:41.347 [kCFStreamSocketSecurityLevelTLSv1_2] -- host:hawk.tagcomp.com -- port:587 -- socket:0x600003c366a0 -- thread:0x6000003e4400
WROTE Jul 07 09:22:41.348 [kCFStreamSocketSecurityLevelTLSv1_2] -- host:hawk.tagcomp.com -- port:587 -- socket:0x600003c366a0 -- thread:0x6000003e4400
AUTH LOGIN
READ Jul 07 09:22:41.384 [kCFStreamSocketSecurityLevelTLSv1_2] -- host:hawk.tagcomp.com -- port:587 -- socket:0x600003c366a0 -- thread:0x6000003e4400
334 VXNlcm5hbWU6
WROTE Jul 07 09:22:41.384 [kCFStreamSocketSecurityLevelTLSv1_2] -- host:hawk.tagcomp.com -- port:587 -- socket:0x600003c366a0 -- thread:0x6000003e4400
amVmZi1tYi1yMTI5LmNvbQ==
READ Jul 07 09:22:41.422 [kCFStreamSocketSecurityLevelTLSv1_2] -- host:hawk.tagcomp.com -- port:587 -- socket:0x600003c366a0 -- thread:0x6000003e4400
334 UGFzc3dvcmQ6
WROTE Jul 07 09:22:41.422 [kCFStreamSocketSecurityLevelTLSv1_2] -- host:hawk.tagcomp.com -- port:587 -- socket:0x600003c366a0 -- thread:0x6000003e4400
READ Jul 07 09:22:43.892 [kCFStreamSocketSecurityLevelTLSv1_2] -- host:hawk.tagcomp.com -- port:587 -- socket:0x600003c366a0 -- thread:0x6000003e4400
WROTE Jul 07 09:22:43.893 [kCFStreamSocketSecurityLevelTLSv1_2] -- host:hawk.tagcomp.com -- port:587 -- socket:0x600003c366a0 -- thread:0x6000003e4400
AUTH LOGIN
READ Jul 07 09:22:43.929 [kCFStreamSocketSecurityLevelTLSv1_2] -- host:hawk.tagcomp.com -- port:587 -- socket:0x600003c366a0 -- thread:0x6000003e4400
334 VXNlcm5hbWU6
WROTE Jul 07 09:22:43.929 [kCFStreamSocketSecurityLevelTLSv1_2] -- host:hawk.tagcomp.com -- port:587 -- socket:0x600003c366a0 -- thread:0x6000003e4400
READ Jul 07 09:22:43.968 [kCFStreamSocketSecurityLevelTLSv1_2] -- host:hawk.tagcomp.com -- port:587 -- socket:0x600003c366a0 -- thread:0x6000003e4400
334 UGFzc3dvcmQ6
WROTE Jul 07 09:22:43.968 [kCFStreamSocketSecurityLevelTLSv1_2] -- host:hawk.tagcomp.com -- port:587 -- socket:0x600003c366a0 -- thread:0x6000003e4400
READ Jul 07 09:22:45.508 [kCFStreamSocketSecurityLevelTLSv1_2] -- host:hawk.tagcomp.com -- port:587 -- socket:0x600003c366a0 -- thread:0x6000003e4400
WROTE Jul 07 09:22:45.509 [kCFStreamSocketSecurityLevelTLSv1_2] -- host:hawk.tagcomp.com -- port:587 -- socket:0x600003c366a0 -- thread:0x6000003e4400
QUIT
are you using the email address as username?
Yes, I am, for both IMAP and SMTP. It’s working for IMAP, but not SMTP.
by the log its not sending a username as its blank. What options have you set for smtp? Looks like a apple device and I’m not familiar with them.
found this may help testing
I also noticed the blank username in the logs, which was curious. In the SMTP trace from the client, you can see the username being transmitted in base64 (I decoded it to make sure it was the correct username). I’ve even tried manually telnetting into port 587 and sending the authentication information by hand and still get the same entries in the log.
(I tried the SMTP test tool, but it’s down right now due to a DDOS attack. )
SMTP test tool is back up, here are the results:
Connected to smtp://hawk.tagcomp.com:587/?starttls=when-available
<< 220 hawk.tagcomp.com ESMTP Postfix
>> EHLO [172.31.11.248]
<< 250-hawk.tagcomp.com
<< 250-PIPELINING
<< 250-SIZE 10240000
<< 250-VRFY
<< 250-ETRN
<< 250-STARTTLS
<< 250-AUTH PLAIN LOGIN
<< 250-AUTH=PLAIN LOGIN
<< 250-ENHANCEDSTATUSCODES
<< 250-8BITMIME
<< 250-DSN
<< 250-SMTPUTF8
<< 250 CHUNKING
>> STARTTLS
<< 220 2.0.0 Ready to start TLS
<< 250-PIPELINING
<< 250-VRFY
<< 250-ETRN
<< 250-8BITMIME
<< 250-DSN
<< 250-SMTPUTF8
<< 250 CHUNKING
>> AUTH PLAIN AGplZmZAbWItcjEyO****************==
<< 535 5.7.8 Error: authentication failed: authentication failure
>> AUTH LOGIN
<< 334 VXNlcm5hbWU6
>> amVmZkBtYi1yMTI5LmNvbQ==
<< 334 UGFzc3dvcmQ6
ERROR: 535: 5.7.8 Error: authentication failed: authentication failure
The username and password are definitely getting transmitted, but the log still says “user unknown” and “ruser=”
I have found the cause of the issue! I installed a minimal install of Rocky 9.2, manually installed wget and perl, then downloaded and ran the virtualmin 7.7 installer. After getting Virtualmin up and running, I experienced the symptoms above, no ability to authenticate via SMTP. (The IMAP authentication fails at the very beginning, but clears up on its own after a few minutes?!?!)
However, when I ran the “dnf groupinstall Server” command, a few hundred more packages were installed. I rebooted the server and, VOILA!, the SMTP authentication began working as expected.
Evidently, there’s some dependency that’s not being addressed in the installer. I’m not sure how to identify it, but I’m happy to work with the developers to track this down.
hmm ok, I would of thought the install scripts would of installed all necessary packages for the system to work or at least have a complaint that something was missing. Not sure if this is a bug.
Joe
July 17, 2023, 6:30pm
11
The only way that would happen is if you’ve configured dnf
to not install default
packages when performing a group install (and only installing mandatory
packages).
Joe
July 17, 2023, 6:32pm
12
To be clear, you shouldn’t need to install the whole Server
group. Just leaving dnf
configured to install default
packages in a group when running the virtualmin-install.sh
should do the job (that is the default on a freshly installed Rocky, for both 8 and 9).
I can’t think of any other package that would be involved, and I can’t think of any other way for installing the Server
group to have fixed it; I’m not saying there isn’t some other explanation, as it’s a complicated system with a lot of moving parts, I just can’t think of any.
system
Closed
September 15, 2023, 6:33pm
13
