upload progress bar not showing
After the last theme update, upload progress bar not showing when uploading a file.
Is there any configuration parameter that is missing?
Webmin 2.610, Usermin 2.510, Virtualmin 7.50.2 GPL, Authentic theme version 26.20
Ubuntu 22.04
Any help will be precious
Thanks!
Thanks for the heads up!
In which module isn’t the file upload showing?
Through Virtualmin, when I use File Manager to upload a file, in previous versions, there was a progress bar (bottom right), that is not anymore visible.
Stelios
Thanks, Stelios! I see this regression too. I’ll look into fixing it and update this ticket with progress.
Thank you very much for your response!
I will wait for your news.
Stelios
that is odd, just been in File Manager (as I seem to spend all my time there)
and the progress bar seems to be there and indicating ok
Windows 11 + Chrome browser
is the issue specific to an OS/browser?
Windows 11 Home & Pro
Browsers: Chrome, Edge, Safari → same behavior
Stelios
is it confined to a specific action during File Manager as I am still not seeing it.
and my screenshot program is too slow to capture it
Alright, I found the bug that was causing it and also fixed quite a few other ugly bugs related to uploads in File Manager. The next Webmin 2.621 release will get it right. Thanks for reporting it!
PERFECT! Thanks
Stelios
