I’m considering upgrading to the pro version of Virtualmin in order to get the application support.
Is it easy / possible to migrate existing running applications (phpbb, coppermine, mediawiki, etc) to be under the control of virtualmin in order to automate updates of these apps? A lot of these apps were deployed on a cpanel+fantastico server that was migrated over. Amazing job on the migration flow, by the way. It was crazy-easy.
You’ll need a second opinion, but afaik the script installer puts a file in /etc/webmin/virtual-server/scriptlog/
the domains are numbered like 1225124778796471.script
inside is something like [code:1]
pass=password
version=5.1.0a
name=sugarcrm
opts_phpver=5
opts_path=/crm
opts_db=mysql_domainname_sugarcrm
opts_dir=/home/domainname/public_html/crm
partial=
desc=Under public_html/crm using mysql database domainname_sugarcrm
url=http://domainname/crm/
user=username
opts_newdb=1
time=1225897787[/code:1]
It seems to me you’ll have to create those files with content and that is gonna be some job…
Thanks Ronald. Looks like it would take some massaging but be possible. Hopefully one of the admins will chime in and see if their is an official migration procedure.
Yeah, unfortunately, there’s no official way to do this (ie, it’s possible it can work, but there’s a fair chance it won’t
The problem is that it’s impossible to know how the app was setup or installed – and that makes it really hard to be able to just import into Virtualmin.
And even if you manage to import it, it’s possible it would break when you later try to upgrade it. Just make sure you have a good backup laying around
