Hi its me again,
I decided to “upgrade” from GPL to Pro. When I use Virtualmin > System Settings > Upgrade to Virtualmin Pro > http://www.virtualmin.com/catalog/19 doesn’t function. Can somebody tell me if this is the right licence to buy at the start: Virtualmin ** Annual License
I only want to know it is the right way.
I wish everybody a bug free 2010 from germany.
Eric
January 1, 2010, 5:45pm
2
Yeah, you would need an annual license.
You should be able to choose the Upgrade to Pro option, and enter the license/serial number if gave you after purchasing the annual license.
What error do you get when attempting to do that?
thank you for the fast reply. When I go in my virtaulmin and klick on
http://www.virtualmin.com/catalog/19 I get:
Die Navigation zu der Webseite wurde abgebrochen.
The navigation to the website was disconnected.
When I copy it into the browser its no problem.
Do you know how long it takes to get the serial?
I bought a Virtualmin Pro ** Annual License at the Virtualmin Shop and paid with credit card.
I was very surprised to get the license immediately.
Wow super. And upgraded immediately my GPL system.
Install Scripts - Brilliant !!!
The only teardrop: Every Alias-Domain is counted as a full Domain. I have to upgrade!!
Until now I’m very impressed by Virtualmin.
