I have just purchased a Pro license and i have no option to upgrade in the config menu under virtualmin or webmin? when i run the license change command i get the following! but i dont have the options in the menu? can anyone shed any light for me ?
GPL repos detected. Use System Settings ⇾ Upgrade to Virtualmin Pro in UI instead to upgrade first!
Updates the Virtualmin Pro license for this system.
virtualmin change-licence --serial number
–key id
[–no-check]
[–force-update]
The install.sh will have some ridiculous name, though, right (like vm-install-pro-10.sh)? We need to fix that. It’s confusing to have to explain the different filenames in every post like this.
@Joe Alright, I have fixed scripts to be called virtualmin-install.sh in Virtualmin → My Account page. I was thinking of using an old name, i.e. install.sh and decided not to… I want the file name to reflect what is getting installed.
If you don’t disagree, and when you update https://software.virtualmin.com/gpl/scripts/virtualmin-install.sh to the latest version, I will update Virtualmin → Download page.
