Upgrade from 50 to 100 Domains
have just purchased license upgrade 50 -> 100 domains, but the license software page has not been updated yet, I still see only previous purchased licence 50 domains.
Is there a way to update my Serverlicense faster because I have a deadline for Monday.
Greetings Swingkid
You should be all set!
If you have any questions, feel free to let us know.
Thanks for using Virtualmin!
I have a little problem with virtualmin serverlist. I can’t use it because it isn’t there. I only can input the server Domain name to configure the server. I don’t get a Domainlist in Virtualmin.
Greetings Jose
It sounds like you may have reached the default limit of Virtual Servers in that drop-down list.
Try going into System Settings -> Virtualmin Config -> User Interface Settings, and set “Maximum number of domains to display” to “Unlimited”.
Okay,
I now see the upgrade under Virtualmin Licenses. I thougt the licensevolume was to small. That wasn’t the case. I wondered because Virtualmin Licenses > Domains Left: 7.
The Problem was:
Try going into System Settings -> Virtualmin Config -> User Interface Settings, and set “Maximum number of domains to display” to “Unlimited”. I didn’t knew that the Domain Display was limitated.
Andreychek, thanks for your help :slight_smile:
If I remember correctly, the limit of 100 was actually removed a little bit ago - maybe a year or two ago – for anyone performing a new installation.
But, for folks like yourself that may have been using Virtualmin for awhile, that limit would still apply, and would need to be tweaked like you just did.
I’m glad it’s working now though!
