Upgrade Advice from Debian 10
I am currently hosting on AWS on Debian 10 which is EOL next month. I am looking to see if there are any details I need to know before upgrading to Debian 13 Trixie. Can I run the Trixie upgrade on the server and then upgrade Virtualmin? Or is there another order or process I should follow.
Thank you for the amazing FOSS software. My server uptime has been over a year hosting several websites on wordpress, etc. and I have barely had to login.
Webmin version 2.111
Usermin version 2.010
Virtualmin version 7.10.0
Debian 10 has been EOL since June last year!
You’d need to upgrade through 11 and 12 (but wait a bit for 13 as it’s not supported by Virtualmin yet).
Also in Debian 13, Dovecot has some major changes that will need some manual intervention I assume.
The upgraded to 11 and 12 should be smooth though, but make sure to backup between upgrades.
Currently, there’s a bug in Debian 13 packaging that prevents the simultaneous installation of firewalld and cloud-init packages.
Running the Virtualmin installer on an EC2 instance will remove cloud-init. It isn’t our fault, and while this may not be a significant issue, it’s important to be aware of it.
I have a personal instance in AWS running Debian 13 without either firewalld or fail2ban at all. I opted for cloud-init, and just use SG instead.
For business purposes, I would currently choose the official Rocky 10 image in AWS. That said, note that the upcoming Virtualmin 8 will have proper support for Rocky 10, but right now it’s only supported in RC repositories.
Thank you all for the info.
Hmm… could you elaborate on why you would not recommend Debian in AWS?
I believe it is more the Debian 13/cloud-init issue than an AWS issue?
Yes, that’s right. It’s an issue upstream right now, and there’s not much we can or should do.
From how I read it is not a Debian bug. They marked cloud-init as conflicting with firewalld, as it can cause a systemd loop problem. Debian bug report:
Where a firewalld can get killed at startup to proceed. I ran into it on Debian 11:
Here’s the firewalld bug report: systemd unit file: possible dependency loop · Issue #414 · firewalld/firewalld · GitHub
And the cloud-init: Bug #1956629 “cloud-init.service/start deleted to break ordering...” : Bugs : cloud-init package : Ubuntu
On Hetzner, where I am, I can just remove cloud-init as it is only used at first boot to install SSH keys, etc. From what I read AWS needs cloud-init installed and the best option is to use the Security Groups external firewall.
