Cowboy
January 18, 2015, 6:42am
1
I apologize for casting my shadow in the forum so soon after my last issue, but this is one that I have no idea how to fix.
I get mail every day from the Cron Daemon.
/etc/cron.daily/logrotate:
[Sun Jan 18 01:20:08 2015] [warn] NameVirtualHost 127.0.0.2:80 has no VirtualHosts
/etc/cron.daily/spamassassin:
channel: attempt to rm channel cf file failed, attempting to continue anyway at /usr/bin/sa-update line 825.
error: can't remove file /var/lib/spamassassin/3.003002/updates_spamassassin_org/20_uri_tests.cf: Permission denied
channel: attempt to rm channel directory failed, attempting to continue anyway at /usr/bin/sa-update line 828.
error: failed to open /var/lib/spamassassin/3.003002/updates_spamassassin_org/10_default_prefs.cf for write: Permission denied at /usr/bin/sa-update line 1118.
channel: archive extraction failed, channel failed
channel: attempt to clean up failed extraction also failed!
sa-update failed for unknown reasons
Does anyone know what this is about and how to fix it for the cron job to complete?
Thanks,
Cowboy
Eric
January 18, 2015, 5:54pm
2
It looks like the SpamAssassin cron job isn’t completing properly.
What is the output of this command:
ls -la /var/lib/spamassassin/3.003002/updates_spamassassin_org/
Cowboy
January 23, 2015, 5:39pm
3
Hi andreychek:
root@dfwit:~# ls -la /var/lib/spamassassin/3.003002/updates_spamassassin_org/
total 1000
drwxr-xr-x 2 root root 4096 Jan 14 01:28 .
drwxr-xr-x 3 root root 4096 Jan 14 01:28 ..
-rw-r--r-- 1 root root 8698 Jan 14 01:28 10_default_prefs.cf
-rw-r--r-- 1 root root 2447 Jan 14 01:28 10_hasbase.cf
-rw-r--r-- 1 root root 7607 Jan 14 01:28 20_advance_fee.cf
-rw-r--r-- 1 root root 9111 Jan 14 01:28 20_aux_tlds.cf
-rw-r--r-- 1 root root 7002 Jan 14 01:28 20_body_tests.cf
-rw-r--r-- 1 root root 1889 Jan 14 01:28 20_compensate.cf
-rw-r--r-- 1 root root 9612 Jan 14 01:28 20_dnsbl_tests.cf
-rw-r--r-- 1 root root 15050 Jan 14 01:28 20_drugs.cf
-rw-r--r-- 1 root root 11497 Jan 14 01:28 20_dynrdns.cf
-rw-r--r-- 1 root root 8512 Jan 14 01:28 20_fake_helo_tests.cf
-rw-r--r-- 1 root root 3012 Jan 14 01:28 20_freemail.cf
-rw-r--r-- 1 root root 41016 Jan 14 01:28 20_freemail_domains.cf
-rw-r--r-- 1 root root 4475 Jan 14 01:28 20_freemail_mailcom_domains.cf
-rw-r--r-- 1 root root 26358 Jan 14 01:28 20_head_tests.cf
-rw-r--r-- 1 root root 10675 Jan 14 01:28 20_html_tests.cf
-rw-r--r-- 1 root root 5285 Jan 14 01:28 20_imageinfo.cf
-rw-r--r-- 1 root root 2662 Jan 14 01:28 20_mailspike.cf
-rw-r--r-- 1 root root 3325 Jan 14 01:28 20_meta_tests.cf
-rw-r--r-- 1 root root 1875 Jan 14 01:28 20_net_tests.cf
-rw-r--r-- 1 root root 15848 Jan 14 01:28 20_pdfinfo.cf
-rw-r--r-- 1 root root 8225 Jan 14 01:28 20_phrases.cf
-rw-r--r-- 1 root root 2057 Jan 14 01:28 20_porn.cf
-rw-r--r-- 1 root root 15965 Jan 14 01:28 20_ratware.cf
-rw-r--r-- 1 root root 5747 Jan 14 01:28 20_uri_tests.cf
-rw-r--r-- 1 root root 19266 Jan 14 01:28 20_vbounce.cf
-rw-r--r-- 1 root root 2751 Jan 14 01:28 23_bayes.cf
-rw-r--r-- 1 root root 1542 Jan 14 01:28 25_accessdb.cf
-rw-r--r-- 1 root root 1534 Jan 14 01:28 25_antivirus.cf
-rw-r--r-- 1 root root 1542 Jan 14 01:28 25_asn.cf
-rw-r--r-- 1 root root 2325 Jan 14 01:28 25_dcc.cf
-rw-r--r-- 1 root root 4405 Jan 14 01:28 25_dkim.cf
-rw-r--r-- 1 root root 2927 Jan 14 01:28 25_hashcash.cf
-rw-r--r-- 1 root root 1308 Jan 14 01:28 25_pyzor.cf
-rw-r--r-- 1 root root 3387 Jan 14 01:28 25_razor2.cf
-rw-r--r-- 1 root root 11330 Jan 14 01:28 25_replace.cf
-rw-r--r-- 1 root root 3424 Jan 14 01:28 25_spf.cf
-rw-r--r-- 1 root root 1766 Jan 14 01:28 25_textcat.cf
-rw-r--r-- 1 root root 13124 Jan 14 01:28 25_uribl.cf
-rw-r--r-- 1 root root 27760 Jan 14 01:28 30_text_de.cf
-rw-r--r-- 1 root root 20467 Jan 14 01:28 30_text_fr.cf
-rw-r--r-- 1 root root 1856 Jan 14 01:28 30_text_it.cf
-rw-r--r-- 1 root root 21536 Jan 14 01:28 30_text_nl.cf
-rw-r--r-- 1 root root 17853 Jan 14 01:28 30_text_pl.cf
-rw-r--r-- 1 root root 45446 Jan 14 01:28 30_text_pt_br.cf
-rw-r--r-- 1 root root 38178 Jan 14 01:28 50_scores.cf
-rw-r--r-- 1 root root 9234 Jan 14 01:28 60_adsp_override_dkim.cf
-rw-r--r-- 1 root root 1314 Jan 14 01:28 60_awl.cf
-rw-r--r-- 1 root root 2178 Jan 14 01:28 60_shortcircuit.cf
-rw-r--r-- 1 root root 5809 Jan 14 01:28 60_whitelist.cf
-rw-r--r-- 1 root root 6194 Jan 14 01:28 60_whitelist_dkim.cf
-rw-r--r-- 1 root root 3582 Jan 14 01:28 60_whitelist_spf.cf
-rw-r--r-- 1 root root 1912 Jan 14 01:28 60_whitelist_subject.cf
-rw-r--r-- 1 root root 247591 Jan 14 01:28 72_active.cf
-rw-r--r-- 1 root root 13678 Jan 14 01:28 72_scores.cf
-rw-r--r-- 1 root root 2674 Jan 14 01:28 73_sandbox_manual_scores.cf
-rw-r--r-- 1 root root 101479 Jan 14 01:28 languages
-rw-r--r-- 1 root root 2213 Jan 14 01:28 local.cf
-rw-r--r-- 1 root root 718 Jan 14 01:28 MIRRORED.BY
-rw-r--r-- 1 root root 2770 Jan 14 01:28 regression_tests.cf
-rw-r--r-- 1 root root 4777 Jan 14 01:28 sa-update-pubkey.txt
-rw-r--r-- 1 root root 1497 Jan 14 01:28 STATISTICS-set0-72_scores.cf.txt
-rw-r--r-- 1 root root 1499 Jan 14 01:28 STATISTICS-set1-72_scores.cf.txt
-rw-r--r-- 1 root root 0 Jan 14 01:28 STATISTICS-set2-72_scores.cf.txt
-rw-r--r-- 1 root root 0 Jan 14 01:28 STATISTICS-set3-72_scores.cf.txt
-rw-r--r-- 1 root root 1869 Jan 14 01:28 user_prefs.template
root@dfwit:~#
Hope this helps.
~Cowboy
