I installed httpd-devel by using
yum install httpd-devel
now how do I remove this and all the packages related to httpd-devel ?
You can remove any package that’s been installed by running this command:
rpm -e PACKAGE_NAME
If there’s any dependencies that also need to be removed, it would tell you about then when you go to remove the package.
What is the difference between
yum remove httpd-devel
and
rpm -e httpd-devel
Nothing, really, there’s multiple ways to remove a package.
I like the rpm command better because it’s less typing
