Unable to open /etc/network/interfaces
Operating system: Ubunty 18.04
OS version:
Hi after last upgrade of webmin ad virtualin this message “Unable to open /etc/network/interfaces” appear when virtual min is loaded and i can’t view summary reports like some days ago.
Can you help me ?
Best Regards
Emiliano
Same problema for me, same OS.
This message apears in several screens. I can’ create a new Virtual Server
Anyone can help us??
Here screens where show the error:
You could try this:
# ifupdown has been replaced by netplan(5) on this system.  See
# /etc/netplan for current configuration.
# To re-enable ifupdown on this system, you can run:
#    sudo apt install ifupdown
Create a file /etc/network/interfaces with the above content, owned by root with 0644 permission. This is what I see on my Virtualmin on Ubuntu 18.04.
All the best!
Good morning, thank you very much, I have applied this solution and everything works normally. Greetings.
Oh, that was a long shot. Glad it worked out.
Thanks for letting us know.
