i installed virtualmin pro version 7.5.2 on Rocky Linux 9. everything went well. but i can’t connect to virtualmin after installation.
what to do?
If you’re on a cloud service like AWS, they block all ports other than 80, 443, and 22 by default at their firewall, which is outside the control of Virtualmin. You’ll have to open the ports for the services you’ll be using. Virtualmin/Webmin is port 10000.
If you’re using Cloudflare, you can’t proxy port 10000. You’ll need to disable Cloudflare proxying for the name you use for management.
