I know it’s only the debian and centos distros the script supports, but Ubuntu is a child of debian so I thought it would work. And what’s stopping me doesn’t seem to be a limitation of ubuntu either - it seems like an apt problem.
Ubuntu 7.04 with the GPL Virtualmin install.sh script.
Please help. Thank you.
INFO - 2007-10-31 20:54:47 - Started installation log in virtualmin-install.log
DEBUG - 2007-10-31 20:54:47 - Install mode: full
DEBUG - 2007-10-31 20:54:47 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2007-10-31 20:54:47 - install.sh version: EA4.2
INFO - 2007-10-31 20:54:47 - Checking for fully qualified hostname...
INFO - 2007-10-31 20:54:47 - Hostname nebraska is not fully qualified.
INFO - 2007-10-31 21:01:17 - Hostname OK: fully qualified as domain.com
INFO - 2007-10-31 21:01:17 - Primary address detected as 64.XX.XX.XX
INFO - 2007-10-31 21:01:17 - Entry for IP 64.XX.XX.XX exists in /etc/hosts.
INFO - 2007-10-31 21:01:17 - Updating with new hostname.
INFO - 2007-10-31 21:01:17 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2007-10-31 21:01:17 - Loading OS selection library...
INFO - 2007-10-31 21:01:18 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2007-10-31 21:01:18 - Loading OS list...
INFO - 2007-10-31 21:01:18 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2007-10-31 21:01:18 - Operating system name: Ubuntu Linux
INFO - 2007-10-31 21:01:18 - Operating system version: 7.04
INFO - 2007-10-31 21:01:18 - Installing virtualmin-release package for Ubuntu Linux 7.04...
INFO - 2007-10-31 21:01:18 - Enabling universe repositories, if not already available...
INFO - 2007-10-31 21:01:21 - Cleaning up apt headers and packages, so we can start fresh...
INFO - 2007-10-31 21:01:22 -
INFO - 2007-10-31 21:01:22 - Download of http://software.virtualmin.com/lib/apt.conf.noninteractive Succeeded.
INFO - 2007-10-31 21:01:22 - Disabling any CD-based apt repositories so the process can run without assistance
INFO - 2007-10-31 21:01:22 - Installing Webmin and Virtualmin package signing keys...
INFO - 2007-10-31 21:01:22 - Download of http://software.virtualmin.com/lib/RPM-GPG-KEY-virtualmin Succeeded.
INFO - 2007-10-31 21:01:22 - Download of http://software.virtualmin.com/lib/RPM-GPG-KEY-webmin Succeeded.
INFO - 2007-10-31 21:01:22 - OK
INFO - 2007-10-31 21:01:23 - Ign
INFO - 2007-10-31 21:01:23 - Removing Debian standard Webmin package, if they exist (because they're broken)...
INFO - 2007-10-31 21:01:23 - Removing Debian apache packages...
DEBUG - 2007-10-31 21:01:24 - Reading
INFO - 2007-10-31 21:01:24 - Installing dependencies using command: /usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install postfix pos
tfix-pcre webmin usermin ruby libapache2-mod-ruby libxml-simple-perl libcrypt-ssleay-perl
INFO - 2007-10-31 21:01:24 - ...in progress, please wait...
Reading package lists...
Building dependency tree...
Reading state information...
Package webmin is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
FATAL - 2007-10-31 21:01:25 - Fatal Error Occurred: Something went wrong during installation: 1
FATAL - 2007-10-31 21:01:25 - Cannot continue installation.
FATAL - 2007-10-31 21:01:25 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2007-10-31 21:01:25 - re-attempted after any problems have been resolved.
FATAL - 2007-10-31 21:01:25 - Removing temporary directory and files.
FATAL - 2007-10-31 21:01:25 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2007-10-31 21:01:25 - in /root/virtualmin-install.log.
Sorry, Ubuntu 7.04 is not supported. There is no repository for it, and thus no packages for it to install–if someone (i.e. me) doesn’t build the packages for the platform, the install definitely will not work. Nothing simple is going to make it work.
Ubuntu 6.06LTS probably will be supported soon in the GPL installer. It already has support in the Professional installer…and that means most of the work is done (it just requires testing, a few script modifications to make the links to the right packages, and some extra hassle during repository maintenance). I think very highly of Ubuntu on the desktop…but only the LTS releases are really suitable for servers. I still prefer Debian in that context, actually. 4.0 is awesome on the server.
