I try to install the SQLite plugin but … I receive the following error:
Failed to save enabled features : The plugin SQLite Databases cannot be used : The command sqlite needed to create SQLite databases is not installed.
Can you help me with this error?
Thanks in advance,
Paul
To make use of plugins in Virtualmin, you need to make sure the underlying software it intends to control is installed.
Navigate to:
Webmin > System > Software Package Updates
Click on:
Only New
Search for:
sqlite
Scroll the list of available packages and find the one you’re interested in installing, place a checkmark beside it, and click “Install Selected Packages”.
*** You could also accomplish this via the Command Line using the “apt” program ***
