Ubuntu 24.04 does not have awscli?
OS type and version ubuntu 24.04
Virtualmin version 7.20.2
Testing backup to S3 account. Ran into trouble:
Failed to save S3 account : S3 account cannot be used : Failed to list S3 buckets : HTTP status 403
Saw notice regarding the need to install AWS CLI… Attempted…
That didn’t seem right. But when I checked on the Ubuntu website it appears to be accurate.
Ubuntu has the package for focal, jammy, oracular, and plucky. But not for noble.
I did search; did not find anything on point.
Is this package required to make S3 backups work?
If so, any ideas for a workaround, or do I need to go back to version 22?
If I don’t need this package, any ideas as to why am not able to create the account?
Many thanks in advance.
Do you use snap? I use rocky I don’t know much about it.
That’s correct, on Ubuntu 24.04, AWS CLI can only be installed from Snap, e.g.:
snap install aws-cli --classic
This worked perfectly!
Many thanks. And as usual, I’m embarrassed I didn’t search generally (a.k.a. Google) for an answer. Was just kind of dumbfounded when I found that ubuntu didn’t include the package.
Thank you Stefan – excellent tip in the right direction.
