Two-factor authentication failed : Missing Perl module Authen::OATH
OS type and version Almalinux 9.1
Webmin version 2.021
I would very much like to know if you use this option because I, although new here, have already used it in other Panels and here it is extremely complicated and difficult to implement and remain active.
Wouldn’t it be a case of being investigated because there are so many flaws?
When the installation is done, the code obtained with Google Authenticator does not allow access, and the system informs you that the Perl module above is missing.
I found this module in Webmin to install and so I did.
I have read many articles, including in this forum but they have not been efficient.
One of them (2020) informs that this module would be automatically active in the next versions.
https://forum.virtualmin.com/t/failed-to-save-two-factor-authentication-the-perl-module-authen-oath-needed-for-two-factor-authentication-is-not-installed/104079
Didn’t that happen? What is the difficulty in the correct implementation? What would I be wrong?
As a security measure I would like to implement two-factor authentication in all main accesses to the websites inserted in the VM.
I haven’t done anything with it but it sounds like you didn’t use this window? Not sure if it helps with VM but I’d start there.
