All:
I am unable to access my system as of two days ago with the repeated error:
Warning!
Two-factor authentication failed : Unknown two-factor authentication failure
How can I fix this? How can I bypass this from command line if needed?
SYSTEM INFORMATION |
OS type and version |
FreeBSD 14.1 |
Webmin version |
Latest - can’t see |
Joe
2
webmin disable-twofactor --user <username>
Joe
4
No. Maybe you’re missing the necessary libraries for 2FA?
Joe
5
To be more clear, you need to look in the log, if there isn’t a useful error in the UI. miniserv.error
is probably the one.
system
Closed
6
