SYSTEM INFORMATION | |
OS type and version: | Ubuntu 20.4 to Debian 10 |
Webmin version: | 1.981 |
Virtualmin version: | 6.17 |
I am using transfer between servers quite a lot. Up to now I was used to edit /etc/webmin/virtual-server/domains/XXXXXXXXX when PHP-FPM version was different between origin and target server (for ex. from PHP 7.4 to PHP 7.3 or vice-versa …) because the transfer utility would not do it, and I would be advised by the fact that FPM would not be available on the target virtual host (PHP Options).
I just discovered that the most recent versions of Virtualmin did address that issue, ie the PHP-FPM version is now correct and the FPM option is already checked if the origin was FPM.
But I did 2 transfers today and target virtual host was not working, error being “file not found” in the browser although no file was missing … after trying different things, like re-transferring a second time, restarting FPM, editing the file mentioned above (that’s how I discovered it had been properly set), I finally switched back to FCGID then back to FPM and everything started to work again …
I first thought something weird happened during transfer but when it happened a second time with another transfer between different servers I decided to report it, it seems that everything is set up properly but it’s missing some kind of restart …
Pierre
