I have same (i think) problem like in this topic OTP code not working
But now luckily i have active session on desktop and i successfully disable the 2FA for root account.
What is main problem?
Enrolling the user again for 2FA the provided code not working in any application.
I try
Google Authenticator iOS
2FAS Auth iOS
none of them working, still got Incorrect OTP when logging in.
OS type and version
Debian Linux 12
Webmin version
2.303
Ilia
July 1, 2025, 3:14pm
2
Make sure your system time is synced. Try running systemctl restart systemd-timesyncd and give it another shot.
Failed to restart systemd-timesyncd.service: Unit systemd-timesyncd.service not found.
Now i try to enable Time server sync schedule but got,
No time servers to sync with entered
Looking into Hardware → System time
seems that the System time is 2 minutes before Hardware time.
What to do and why this becomes a problem over time?
Ilia
July 1, 2025, 3:39pm
4
Does your Debian 12 not have the systemd init system?
timedatectl status
Local time: Tue 2025-07-01 17:40:52 CEST
Universal time: Tue 2025-07-01 15:40:52 UTC
RTC time: Tue 2025-07-01 15:42:38
Time zone: Europe/Skopje (CEST, +0200)
System clock synchronized: no
NTP service: n/a
RTC in local TZ: no
Ilia
July 1, 2025, 3:55pm
6
Then do:
apt-get install systemd-timesyncd
and
systemctl enable --now systemd-timesyncd
Okay, now synchronized is yes and NTP is active .
I also enable the time sync schedule successfully for 4 times a day.
I hope never happen again.
