I have try the command shell under webmin tool. previously all is working fine which we can run script/command from this shell. but now not working. it kept loading infinite. i have try both ubuntu and almalinux. it could be the bug. cause when i try this command using the ssh/terminal it was working fine
yes, this is what i mean. forever loop without result. Webmin ā Tools ā Command Shell. cannot remember what is the last work version. should be 2 version before that.
Yes I tested on Webmin module first when I read your post.
My second post just attempted to clarify it worked initially with the simple cd command but then failed with a script/shell command.
I added the note on Virtualmin to clarify that I was aware you were referring to Webmin. Just in case others were going to attempt to use the option of running a command there instead. I realise that is not available to you.
Oh, Iām sorry. I forgot to provide feedback. This issue was fixed the same day it was reported. It was a bug on the theme side. You just need to upgrade the Authentic theme manually using the Theme Configuration page to the latest development version if you feel comfortable doing so, or just wait for another Webmin release.
