Tiny docs proofreading comment
Hi! I’ve been impressed with Virtualmin so far. I’m new to it, having messed around with cPanel and Plesk some in the past.
I just notice a very minor little glitch in the docs, in " How to Add an SSL Certificate".
It says, “Before continuing make sure that SSL website enabled feature is enabled in Edit Virtual Server page.”
If I read this correctly, that option is no longer there. Jamie, Virtualmin Staff:
“In Virtualmin 7.5, by default when you create a new domain and check the ‘Setup Apache website’ option an SSL website will also be enabled automatically. Our thinking is that there’s no reason not to always enabled SSL…”
Anyway, if the option it’s there I couldn’t find it, and apparently didn’t need it. :slightly_smiling_face:
Dan
p.s. I will say, too, also on a very minor note, I may not be the only one to notice in this forum that over here to my right, “Your topic is similar to…” is I guess about 180 degrees off the mark! A random topic generator could do almost as well – but that’s probably the forum software and not you guys!
Thats true, docs could be updated on that.
You can see it if you untick it being a default for future reference.
Thanks for the heads up! We will fix that!
