We need relevant entries from the error_log. There’s nothing there in the journal, and status never shows anything useful.
Here is the error_log
/var/log/virtualmin/mywebsite.com_error_log
[Sun Mar 10 12:54:39.855892 2024] [proxy_fcgi:error] [pid 554620:tid 139895993521920] [client xxx.xxx.xxx.xxx:55645] AH01071: Got error 'Primary script unknown'
[Mon Mar 11 22:51:57.314679 2024] [ssl:error] [pid 846422:tid 139896572290816] [client xx.xxx.xx.xxx:36882] AH02032: Hostname totalrepair-ms.com provided via SNI and hostname mywebsite.com provided via HTTP have no compatible SSL setup
[Tue Mar 12 12:35:57.772125 2024] [autoindex:error] [pid 846422:tid 139896639432448] [client xx.xx.x.xxx:64117] AH01276: Cannot serve directory /home/mywebsite/public_html/wp-admin/css/: No matching DirectoryIndex (index.php,index.php4,index.php5,index.htm,index.html) found, and server-generated directory index forbidden by Options directive, referer: binance.com
[Wed Mar 13 18:09:43.997393 2024] [proxy_fcgi:error] [pid 846422:tid 139896781637376] [client xxx.xxx.xxx.xxx:52342] AH01071: Got error 'Primary script unknown'
[Wed Mar 13 18:09:44.917046 2024] [proxy_fcgi:error] [pid 846422:tid 139896589076224] [client xxx.xxx.xxx.xxx:52342] AH01071: Got error 'Primary script unknown'
[Wed Mar 13 18:09:50.049269 2024] [autoindex:error] [pid 846422:tid 139896781637376] [client xxx.xxx.xxx.xxx:52342] AH01276: Cannot serve directory /home/mywebsite/public_html/wp-admin/css/: No matching DirectoryIndex (index.php,index.php4,index.php5,index.htm,index.html) found, and server-generated directory index forbidden by Options directive
[Wed Mar 13 18:09:51.414902 2024] [autoindex:error] [pid 846422:tid 139896572290816] [client xxx.xxx.xxx.xxx:52342] AH01276: Cannot serve directory /home/mywebsite/public_html/wp-admin/images/: No matching DirectoryIndex (index.php,index.php4,index.php5,index.htm,index.html) found, and server-generated directory index forbidden by Options directive
[Wed Mar 13 18:09:51.511653 2024] [autoindex:error] [pid 846422:tid 139896614254336] [client xxx.xxx.xxx.xxx:52342] AH01276: Cannot serve directory /home/mywebsite/public_html/wp-admin/css/colors/: No matching DirectoryIndex (index.php,index.php4,index.php5,index.htm,index.html) found, and server-generated directory index forbidden by Options directive
[Fri Mar 15 14:34:10.864598 2024] [autoindex:error] [pid 846422:tid 139896513541888] [client xx.xxx.xxx.xxx:65046] AH01276: Cannot serve directory /home/mywebsite/public_html/wp-admin/css/: No matching DirectoryIndex (index.php,index.php4,index.php5,index.htm,index.html) found, and server-generated directory index forbidden by Options directive, referer: binance.com
[Fri Mar 15 20:52:31.832057 2024] [autoindex:error] [pid 846422:tid 139896530327296] [client xxx.xx.xx.xx:57518] AH01276: Cannot serve directory /home/mywebsite/public_html/wp-admin/css/: No matching DirectoryIndex (index.php,index.php4,index.php5,index.htm,index.html) found, and server-generated directory index forbidden by Options directive, referer: www.mywebsite.com
[Fri Mar 15 22:41:46.583230 2024] [autoindex:error] [pid 554338:tid 139896589076224] [client xxx.xxx.xx.xx:44906] AH01276: Cannot serve directory /home/mywebsite/public_html/wp-admin/css/: No matching DirectoryIndex (index.php,index.php4,index.php5,index.htm,index.html) found, and server-generated directory index forbidden by Options directive, referer: mywebsite.com
No. not the domain error_log. The error_log for Apache itself. The domain error_log obviously won’t have anything because Apache isn’t even starting, so it can’t be serving requests for domains to generate errors.
I already shared it above ! But here is it:
/etc/httpd/logs/error_log
[Sun Mar 17 15:26:50.680275 2024] [suexec:notice] [pid 971:tid 140245147683136] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
AH00016: Configuration Failed
[Mon Mar 18 12:10:49.639684 2024] [suexec:notice] [pid 907:tid 140484725803328] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Tue Mar 19 02:15:34.371948 2024] [suexec:notice] [pid 987:tid 139863776864576] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Tue Mar 19 05:05:59.819884 2024] [suexec:notice] [pid 984:tid 140279311661376] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Tue Mar 19 06:08:45.542503 2024] [suexec:notice] [pid 891:tid 139621021817152] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Tue Mar 19 13:39:15.166485 2024] [suexec:notice] [pid 67999:tid 140472081021248] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Tue Mar 19 13:57:02.441651 2024] [suexec:notice] [pid 74001:tid 140404439783744] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Tue Mar 19 17:32:44.891232 2024] [suexec:notice] [pid 115489:tid 140561566751040] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Tue Mar 19 17:32:54.592015 2024] [suexec:notice] [pid 115937:tid 140607607167296] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Tue Mar 19 17:33:12.064927 2024] [suexec:notice] [pid 117001:tid 140129764096320] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Tue Mar 19 17:59:46.673262 2024] [suexec:notice] [pid 124772:tid 139837902453056] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Tue Mar 19 17:04:02.439633 2024] [suexec:notice] [pid 903:tid 140108694559040] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Tue Mar 19 18:05:37.108016 2024] [suexec:notice] [pid 2654:tid 140580508637504] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Tue Mar 19 19:10:53.047670 2024] [suexec:notice] [pid 17346:tid 140393640999232] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
There has to be more than that!
[Sun Feb 18 03:41:03.235507 2024] [lbmethod_heartbeat:notice] [pid 949:tid 140165411916096] AH02282: No slotmem from mod_heartmonitor
[Sun Feb 18 03:41:03.272237 2024] [mpm_event:notice] [pid 949:tid 140165411916096] AH00489: Apache/2.4.37 (centos) OpenSSL/1.1.1k mod_fcgid/2.3.9 configured -- resuming normal operations
[Sun Feb 18 03:41:03.272395 2024] [core:notice] [pid 949:tid 140165411916096] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Sun Feb 18 03:41:03.531515 2024] [mpm_event:notice] [pid 949:tid 140165411916096] AH00493: SIGUSR1 received. Doing graceful restart
[Sun Feb 18 03:41:03.931582 2024] [lbmethod_heartbeat:notice] [pid 949:tid 140165411916096] AH02282: No slotmem from mod_heartmonitor
[Sun Feb 18 03:41:03.948789 2024] [mpm_event:notice] [pid 949:tid 140165411916096] AH00489: Apache/2.4.37 (centos) OpenSSL/1.1.1k mod_fcgid/2.3.9 configured -- resuming normal operations
[Sun Feb 18 03:41:03.948822 2024] [core:notice] [pid 949:tid 140165411916096] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Mon Feb 19 11:36:59.895994 2024] [suexec:notice] [pid 917:tid 140388287437120] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Mon Feb 19 11:37:00.263425 2024] [lbmethod_heartbeat:notice] [pid 917:tid 140388287437120] AH02282: No slotmem from mod_heartmonitor
[Mon Feb 19 11:37:00.318386 2024] [mpm_event:notice] [pid 917:tid 140388287437120] AH00489: Apache/2.4.37 (centos) OpenSSL/1.1.1k mod_fcgid/2.3.9 configured -- resuming normal operations
[Mon Feb 19 11:37:00.318470 2024] [core:notice] [pid 917:tid 140388287437120] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Mon Feb 19 12:43:09.978613 2024] [mpm_event:notice] [pid 917:tid 140388287437120] AH00493: SIGUSR1 received. Doing graceful restart
[Mon Feb 19 12:43:13.421396 2024] [lbmethod_heartbeat:notice] [pid 917:tid 140388287437120] AH02282: No slotmem from mod_heartmonitor
[Mon Feb 19 12:43:13.460272 2024] [mpm_event:notice] [pid 917:tid 140388287437120] AH00489: Apache/2.4.37 (centos) OpenSSL/1.1.1k mod_fcgid/2.3.9 configured -- resuming normal operations
[Mon Feb 19 12:43:13.460329 2024] [core:notice] [pid 917:tid 140388287437120] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Mon Feb 19 12:43:52.700844 2024] [mpm_event:error] [pid 917:tid 140388287437120] (12)Cannot allocate memory: AH00481: fork: Unable to fork new process
[Mon Feb 19 12:44:15.378048 2024] [mpm_event:error] [pid 917:tid 140388287437120] (12)Cannot allocate memory: AH00481: fork: Unable to fork new process
[Sat Feb 24 11:32:36.376507 2024] [suexec:notice] [pid 904:tid 139678741326144] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Sat Feb 24 11:32:36.639522 2024] [lbmethod_heartbeat:notice] [pid 904:tid 139678741326144] AH02282: No slotmem from mod_heartmonitor
[Sat Feb 24 11:32:36.676687 2024] [mpm_event:notice] [pid 904:tid 139678741326144] AH00489: Apache/2.4.37 (centos) OpenSSL/1.1.1k mod_fcgid/2.3.9 configured -- resuming normal operations
[Sat Feb 24 11:32:36.676749 2024] [core:notice] [pid 904:tid 139678741326144] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Sat Feb 24 12:35:37.731858 2024] [mpm_event:notice] [pid 904:tid 139678741326144] AH00493: SIGUSR1 received. Doing graceful restart
[Sat Feb 24 12:35:40.937416 2024] [lbmethod_heartbeat:notice] [pid 904:tid 139678741326144] AH02282: No slotmem from mod_heartmonitor
[Sat Feb 24 12:35:40.943778 2024] [mpm_event:notice] [pid 904:tid 139678741326144] AH00489: Apache/2.4.37 (centos) OpenSSL/1.1.1k mod_fcgid/2.3.9 configured -- resuming normal operations
[Sat Feb 24 12:35:40.943822 2024] [core:notice] [pid 904:tid 139678741326144] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Sun Feb 25 03:35:02.355825 2024] [mpm_event:notice] [pid 904:tid 139678741326144] AH00493: SIGUSR1 received. Doing graceful restart
[Sun Feb 25 03:35:03.798053 2024] [lbmethod_heartbeat:notice] [pid 904:tid 139678741326144] AH02282: No slotmem from mod_heartmonitor
[Sun Feb 25 03:35:04.042452 2024] [mpm_event:notice] [pid 904:tid 139678741326144] AH00489: Apache/2.4.37 (centos) OpenSSL/1.1.1k mod_fcgid/2.3.9 configured -- resuming normal operations
[Sun Feb 25 03:35:04.042678 2024] [core:notice] [pid 904:tid 139678741326144] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Sun Feb 25 03:35:06.400705 2024] [mpm_event:notice] [pid 904:tid 139678741326144] AH00493: SIGUSR1 received. Doing graceful restart
[Sun Feb 25 03:35:06.540701 2024] [lbmethod_heartbeat:notice] [pid 904:tid 139678741326144] AH02282: No slotmem from mod_heartmonitor
[Sun Feb 25 03:35:06.544683 2024] [mpm_event:notice] [pid 904:tid 139678741326144] AH00489: Apache/2.4.37 (centos) OpenSSL/1.1.1k mod_fcgid/2.3.9 configured -- resuming normal operations
[Sun Feb 25 03:35:06.544715 2024] [core:notice] [pid 904:tid 139678741326144] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Sun Feb 25 19:21:33.402883 2024] [suexec:notice] [pid 955:tid 139865619507520] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Sun Feb 25 19:21:33.757247 2024] [lbmethod_heartbeat:notice] [pid 955:tid 139865619507520] AH02282: No slotmem from mod_heartmonitor
[Sun Feb 25 19:21:33.790824 2024] [mpm_event:notice] [pid 955:tid 139865619507520] AH00489: Apache/2.4.37 (centos) OpenSSL/1.1.1k mod_fcgid/2.3.9 configured -- resuming normal operations
[Sun Feb 25 19:21:33.790893 2024] [core:notice] [pid 955:tid 139865619507520] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Tue Feb 27 12:47:54.436947 2024] [suexec:notice] [pid 973:tid 140326704834880] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Tue Feb 27 12:47:54.655090 2024] [lbmethod_heartbeat:notice] [pid 973:tid 140326704834880] AH02282: No slotmem from mod_heartmonitor
[Tue Feb 27 12:47:54.686657 2024] [mpm_event:notice] [pid 973:tid 140326704834880] AH00489: Apache/2.4.37 (centos) OpenSSL/1.1.1k mod_fcgid/2.3.9 configured -- resuming normal operations
[Tue Feb 27 12:47:54.686746 2024] [core:notice] [pid 973:tid 140326704834880] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Sun Mar 03 03:49:03.366502 2024] [mpm_event:notice] [pid 973:tid 140326704834880] AH00493: SIGUSR1 received. Doing graceful restart
[Sun Mar 03 03:49:04.434473 2024] [lbmethod_heartbeat:notice] [pid 973:tid 140326704834880] AH02282: No slotmem from mod_heartmonitor
[Sun Mar 03 03:49:04.473775 2024] [mpm_event:notice] [pid 973:tid 140326704834880] AH00489: Apache/2.4.37 (centos) OpenSSL/1.1.1k mod_fcgid/2.3.9 configured -- resuming normal operations
[Sun Mar 03 03:49:04.474462 2024] [core:notice] [pid 973:tid 140326704834880] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Sun Mar 03 03:49:06.587987 2024] [mpm_event:notice] [pid 973:tid 140326704834880] AH00493: SIGUSR1 received. Doing graceful restart
[Sun Mar 03 03:49:09.714778 2024] [lbmethod_heartbeat:notice] [pid 973:tid 140326704834880] AH02282: No slotmem from mod_heartmonitor
[Sun Mar 03 03:49:09.726831 2024] [mpm_event:notice] [pid 973:tid 140326704834880] AH00489: Apache/2.4.37 (centos) OpenSSL/1.1.1k mod_fcgid/2.3.9 configured -- resuming normal operations
[Sun Mar 03 03:49:09.726874 2024] [core:notice] [pid 973:tid 140326704834880] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Sun Mar 03 13:13:35.118858 2024] [mpm_event:notice] [pid 973:tid 140326704834880] AH00493: SIGUSR1 received. Doing graceful restart
[Sun Mar 03 13:13:36.709590 2024] [lbmethod_heartbeat:notice] [pid 973:tid 140326704834880] AH02282: No slotmem from mod_heartmonitor
[Sun Mar 03 13:13:36.727057 2024] [mpm_event:notice] [pid 973:tid 140326704834880] AH00489: Apache/2.4.37 (centos) OpenSSL/1.1.1k mod_fcgid/2.3.9 configured -- resuming normal operations
[Sun Mar 03 13:13:36.727098 2024] [core:notice] [pid 973:tid 140326704834880] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Sun Mar 03 15:32:46.725591 2024] [suexec:notice] [pid 930:tid 139839148050752] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Sun Mar 03 15:32:46.908273 2024] [lbmethod_heartbeat:notice] [pid 930:tid 139839148050752] AH02282: No slotmem from mod_heartmonitor
[Sun Mar 03 15:32:46.942807 2024] [mpm_event:notice] [pid 930:tid 139839148050752] AH00489: Apache/2.4.37 (centos) OpenSSL/1.1.1k mod_fcgid/2.3.9 configured -- resuming normal operations
[Sun Mar 03 15:32:46.942863 2024] [core:notice] [pid 930:tid 139839148050752] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Sun Mar 03 21:38:37.607654 2024] [mpm_event:notice] [pid 930:tid 139839148050752] AH00493: SIGUSR1 received. Doing graceful restart
[Sun Mar 03 21:38:37.975633 2024] [lbmethod_heartbeat:notice] [pid 930:tid 139839148050752] AH02282: No slotmem from mod_heartmonitor
[Sun Mar 03 21:38:38.005093 2024] [mpm_event:notice] [pid 930:tid 139839148050752] AH00489: Apache/2.4.37 (centos) OpenSSL/1.1.1k mod_fcgid/2.3.9 configured -- resuming normal operations
[Sun Mar 03 21:38:38.005154 2024] [core:notice] [pid 930:tid 139839148050752] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Thu Mar 07 22:55:24.665603 2024] [suexec:notice] [pid 918:tid 139897421924672] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Thu Mar 07 22:55:25.008625 2024] [lbmethod_heartbeat:notice] [pid 918:tid 139897421924672] AH02282: No slotmem from mod_heartmonitor
[Thu Mar 07 22:55:25.036178 2024] [mpm_event:notice] [pid 918:tid 139897421924672] AH00489: Apache/2.4.37 (centos) OpenSSL/1.1.1k mod_fcgid/2.3.9 configured -- resuming normal operations
[Thu Mar 07 22:55:25.036243 2024] [core:notice] [pid 918:tid 139897421924672] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Sun Mar 10 03:25:02.455417 2024] [mpm_event:notice] [pid 918:tid 139897421924672] AH00493: SIGUSR1 received. Doing graceful restart
[Sun Mar 10 03:25:06.933527 2024] [lbmethod_heartbeat:notice] [pid 918:tid 139897421924672] AH02282: No slotmem from mod_heartmonitor
[Sun Mar 10 03:25:06.946605 2024] [mpm_event:notice] [pid 918:tid 139897421924672] AH00489: Apache/2.4.37 (centos) OpenSSL/1.1.1k mod_fcgid/2.3.9 configured -- resuming normal operations
[Sun Mar 10 03:25:06.946762 2024] [core:notice] [pid 918:tid 139897421924672] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Sun Mar 10 03:25:06.946775 2024] [mpm_event:notice] [pid 918:tid 139897421924672] AH00493: SIGUSR1 received. Doing graceful restart
[Sun Mar 10 03:25:07.067345 2024] [lbmethod_heartbeat:notice] [pid 918:tid 139897421924672] AH02282: No slotmem from mod_heartmonitor
[Sun Mar 10 03:25:07.070857 2024] [mpm_event:notice] [pid 918:tid 139897421924672] AH00489: Apache/2.4.37 (centos) OpenSSL/1.1.1k mod_fcgid/2.3.9 configured -- resuming normal operations
[Sun Mar 10 03:25:07.070885 2024] [core:notice] [pid 918:tid 139897421924672] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Fri Mar 15 22:43:32.173751 2024] [mpm_event:notice] [pid 918:tid 139897421924672] AH00493: SIGUSR1 received. Doing graceful restart
[Fri Mar 15 22:43:33.049744 2024] [lbmethod_heartbeat:notice] [pid 918:tid 139897421924672] AH02282: No slotmem from mod_heartmonitor
[Fri Mar 15 22:43:33.084859 2024] [mpm_event:notice] [pid 918:tid 139897421924672] AH00489: Apache/2.4.37 (centos) OpenSSL/1.1.1k mod_fcgid/2.3.9 configured -- resuming normal operations
[Fri Mar 15 22:43:33.085017 2024] [core:notice] [pid 918:tid 139897421924672] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Fri Mar 15 23:00:22.713016 2024] [mpm_event:notice] [pid 918:tid 139897421924672] AH00493: SIGUSR1 received. Doing graceful restart
[Fri Mar 15 23:00:25.815677 2024] [lbmethod_heartbeat:notice] [pid 918:tid 139897421924672] AH02282: No slotmem from mod_heartmonitor
[Fri Mar 15 23:00:25.819256 2024] [mpm_event:notice] [pid 918:tid 139897421924672] AH00489: Apache/2.4.37 (centos) OpenSSL/1.1.1k mod_fcgid/2.3.9 configured -- resuming normal operations
[Fri Mar 15 23:00:25.819283 2024] [core:notice] [pid 918:tid 139897421924672] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Fri Mar 15 23:19:08.034757 2024] [mpm_event:notice] [pid 918:tid 139897421924672] AH00493: SIGUSR1 received. Doing graceful restart
[Fri Mar 15 23:19:08.388406 2024] [:emerg] [pid 918:tid 139897421924672] AH00020: Configuration Failed, exiting
[Fri Mar 15 22:32:20.200139 2024] [suexec:notice] [pid 934:tid 140141238626624] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Fri Mar 15 22:36:41.664831 2024] [suexec:notice] [pid 979:tid 140619189266752] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Fri Mar 15 23:29:40.538769 2024] [suexec:notice] [pid 900:tid 140345416743232] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Sat Mar 16 04:25:25.452193 2024] [suexec:notice] [pid 931:tid 140302252927296] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Sat Mar 16 13:49:33.087858 2024] [suexec:notice] [pid 931:tid 140104191854912] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Sat Mar 16 18:33:25.568497 2024] [suexec:notice] [pid 946:tid 139951614245184] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
lol. You’re running out of memory.
WOW ! How am i running out of memory, please look at this
Look at CPU, RAM and Space
and if this is the case (running out of memory), can you please tell me what to do to get things working, a trick or something, for example removing some server installations (subdomains) and keep trying to run the Apache Webserver or what ?!
Tell me please …
I disabled all web servers and Apache Webserver still doesn’t want to run, so the problem is not the memory + previously that “memory problem” when it happens very rarely I simply restart the server and everything works fine !
Oh, nevermind, the memory errors are old.
You obviously have a configuration problem. Run this:
apachectl configtest
Result:
[root@vmiXXXXX ~]# apachectl configtest
Syntax OK
You’ve stumped me. It’s not a problem I’ve seen.
But, Googling gives hints that it’s a broken SSL certificate (wrong format, corrupt file, something along those lines). So, disable SSL for all your domains, and try again. If that doesn’t fix it, find whatever other SSL certs are referenced (outside of Virtualmin managed domains, since disabling SSL in your domains should remove references to the certificates in those domains). Then, once Apache is running again, you can generate new certificates…and figure out what you did to get to where you are. Someone suggested in a StackOverflow discussion that upgrading the OpenSSL version can do it, which would align with the theory that you upgraded your OS.
Thank you Joe for your assistance, I appreciate it !
Unfortunately I can’t try that solution because I took a backup of all websites and I removed everything, changed my VPS provider, … Now my websites are running fine in my new VPS !
Yes, I have a feeling it was an SSL certificate issue that caused the problem, because while exporting one of my websites to the new destination I noticed an SSL_ERROR, so I’m going to consider your last answer as a solution.
Thank you again,
