Hello everyone,
The installation of Virtualmin on Ubuntu 22.04 and 24.04 stops during the installation process.
I have attached a screenshot of the stoppage point and the log.
I would appreciate any guidance.
Hello everyone,
I haven’t installed for a while but I recall that step can take awhile depending on your system hardware. I think I restarted the process when I initially did it and it completed.
20 minutes to an hour should cover it.
It does take a while and all depends on your system and internet.
I can’t think of anything during postinstall of webmin-virtual-server
that could hang, but maybe something has been added.
Take a look at ps aux|grep perl
Look for something currently running from one of the Webmin directories…maybe postinstall.pl
. If you see that, run the following command (you’ll probably need to install strace
strace -p <pid-of-postinstall.pl>
(Obviously, replace “<pid-of-postinstall.pl>” with the actual PID of the postinstal.pl process you can see in the ps
output above.)
If you don’t see a postinstall.pl
running, show us what Webmin processes you do see.
