guzabi
1
Since upgrading Webmin do 1.520, I’ve got this error everyday at 23:30 (I receive it in my mail because it’s triggered by a cron task) :
Failed to run /usr/libexec/webmin/cron/tempdelete.pl : No such file or directory at /etc/webmin/cron/tempdelete.pl line 11.
- It’s annoying
- It’s a little alarming
Can I have support on this please ?
Thanks.
Eric
2
Mmm, that sounds like a bug of some sort.
My recommendation would be to file a bug report, using the Support link above. Jamie can then work with you to figure out what’s going on there.
Thanks!
DaveQB
3
I can confirm this issue.
Bug number??
Eric
4
There’s a bug report and fix for that here:
http://www.virtualmin.com/node/15526
