in Virtual Min Pro there is a link “System Statistics” which shows a graphical representation of usage.
however, it seems to have stuck on the 15th March.
any advice on how this can be reset or reconfigured?
thanks
thanks
I believe those statistics are all collected by the collectinfo.pl program, which is run from cron.
Is that program still running regularly? You can look in the logfiles, and search on the name “collectinfo”, to see when it ran last.
yes, it is in cron and active, I’ll have a look in the logfiles
thanks
