Hi people.
Im running a test on a VM that involves setting up virtualmin.
ive installed it successfully and run through the post install config.
when it comes to checking the config i get this error:
“The Suexec command on your system is configured to only run scripts under /var/www, but the Virtualmin base directory is /home. CGI and PHP scripts run as domain owners will not be executed.”
im running it on ubuntu 9.04 x64. i know that it isnt a supported distro, but is part of my testing.
how do i recompile suexec to use the virtualmin home directory?
Thanks in advanced
Ash
