| SYSTEM INFORMATION | |
| OS type and version | Ubuntu Linux 22.04.4 |
| Webmin version | 2.111 |
| Usermin version | 2.010 |
| Virtualmin version | 7.10.0 Pro |
| Theme version | 21.10 |
| Package updates | All installed packages are up to date |
This is a discussion and not a call for help of any kind, regarding the pros & cons of using System Monitors over Servers Status
you can simulate the Servers Status and perhaps add a couple more services
as you can see from this screen shot I added both fail2ban & usermin status
Monitors
Pros ( as I see it)
- The ability to monitor everything that is or should be running.
- The ability to monitor services on remote installs of virtualmin
- The ability to attempt to restart a service (local or remote) that has gone down
- Emails are sent on service failure and service restoration
Cons
- The inability to sort the monitors alphabetically
- The inability to go to the webmin module (local or remote) via a link in the monitor
- The inability to restart or stop the service via link in the monitor (the stop link may not be required, as if you stop it the monitor may retry to start the service if you have set the monitor to restart the service on failure/stop)
- The System Monitors accordion can get huge if you are monitoring multiple servers
Example :
- The ability to monitor remote webmin installs is dependant on having webmin clustering setup and working or work out the http/ping requests from the remote server you are querying
Servers Status
Pros
- Works out of the box if you have virtualmin installed
- Allows you to restart/stop the service
Cons
- The inability to sort services alphabetically
- The inability to add a service to the server status
- Is not present in a webmin only system
There may be more pros & cons for each, this only from how I use the 2 functions.
Perhaps @shoulders you are right, the 2 functions could be combined to produce something that works across both webmin and virtualmin
