Superuser privileges issue
AlmaLinux 8.9 REQUIRED
Webmin 2.111 REQUIRED
I’m trying to set a new PHP package using the following command :
dnf install php81-php-{cli,fpm,pdo,gd,mbstring,mysqlnd,opcache,curl,xml,zip}
And have the following issue:
Error: This command has to be run with superuser privileges (under the root user on most systems).
I tried to activate Allow users who can run all commands via sudo to login as root in : Webmin → Webmin users → Unix User Authentication
Also tried to activate all Available Webmin Modules for the specific user I have (not root, but I’m connected to Webmin with root…)
Thanks.
If the user is in the sudo (wheel) group just prefix the command with sudo
When i prefix with sudo, it asks me for the specific user password then :
“user” is not in the sudoers file. This incident will be reported.
seen this solution
su root
nano /etc/sudoers
Then add the user below admin user like below syntax.
user_name ALL=(ALL)  ALL
Nevermind, I just connected to the terminal again and i’m on root now. I don’t know if it took some times for the modifications I made to apply but it works now.
