Suggestions for a Virtualmin Equivalent to Imunify AV (malware scanner for WP sites)
| Operating system | Rocky Linux 9.8 |
| Webmin version | 2.641 | Usermin version | 2.540 |
| Virtualmin version | 8.1.0 Professional | Authentic theme version | 26.41.1
On my soon to be retired cPanel servers, I have a free version of Imunify AV which has saved me a couple of times in the past because it scans website files for malicious code weekly (occasionally has picked up a malicious attempt from an outdated plugin etc).
I am using Virtualmin Pro and wp workbench - just wondering what you would recommend that would be a free drop in plugin that will provide a malicious file scan - similar to Imunify AV. I’d rather not use Clam AV as have had poor experience with that in the past.
I’ve discovered cPGuard and Maldet but just wondering what other people use and the recommendations…
AV and antimalware via scanning every file on a system is a complicated problem, because introducing a root level tool to read all files on a system expands the attack surface of your system. When you “scan” a system with AV, you’re essentially letting attackers that can reach your email talk directly to a root executable on your system. Pretty high risk behavior.
There are mitigations for the risk (using a scanner that runs as a non-root user, and the root process hands each file over to that scanning process for analysis…assuming the root-level executable that does the reading is small and secure, the attack surface is minimized, and if your AV tool has an exploit it can only ever damage the service users files, absent availability of other escalation exploits). I’ve seen many folks implement virus scanning in a way that makes their system less safe. And, there have been serious exploits of Symantec, McAfee, Windows Defender, etc.
When ClamAV is installed with Virtualmin, we setup a clam@scan service (or something like that, I don’t remember exactly) that runs as a non-privileged user. But, we only set it up to scan email. You could set up another job to use that scan service to process all files on the system periodically. Pretty heavy solution, maybe focus only on files domain owner and email users can change. (Though if you’re scanning incoming email, scanning user mailboxes is less pressing).
ClamAV is what we support, but we’re not stopping you from using anything else. Maldet gets it signatures from the ClamAV project, AFAIK, so I’m not sure there’s a benefit to running it in addition to ClamAV (I don’t have any experience with it).
I don’t want to guess what “poor experience with ClamAV” means. I mean, I don’t like it, as it’s very resource-intensive. But, most AVs are, and there are many I would consider a much higher risk to run. They did just prune a bunch of old signatures from the default database a little while back, so it’s not as heavy as it used to be…but, still, scanning for a gazillion AV signatures is just a hard job. No amount of efficient coding makes it not a hard problem.
I am, personally, very suspicious of proprietary AV (again, because it is a huge attack surface), and I’m also suspicious of new AV products. Not saying there aren’t good ones. I just don’t know how you’d really know unless and until there’s an exploit (and it seems like there’s always an exploit, eventually). And, most of them are repackaging the same AV signatures everybody else has (including ClamAV). You’re maybe mostly paying for packaging and branding.
I did a little research on the current state of things, and this seems very promising: GitHub - aquasecurity/tracee: Linux Runtime Security and Forensics using eBPF · GitHub
e.g. it has stuff like this: TRACEE-ILLEGITIMATE-SHELL - Tracee
and: TRACEE-SCHEDULED-TASK-MODIFICATION - Tracee
Tetragon is another in the same vein: https://tetragon.io/
Oh, also, part of the weight of ClamAV is the size of its database of signatures. For a Linux system, something like 2/3 of the signatures are meaningless.
I built a tool for pruning ClamAV sig databases, which reduces the resource consumption by quite a lot. GitHub - swelljoe/clam-juice: A tool to filter ClamAV signature database by type · GitHub
I would like a system wide malware scanner, one that can be run by admins and then an option for individual virtual servers.
I think this is needed, it might not fix a website but it will alert the relevant people that a site has been hacked.
Thanks @Joe for your time and detailed reply.
My comment “poor experience with ClamAV” was exactly as you alluded to in your response - it’s so resource hungry it kept crashing my server and I found the only resolution was to uninstall it - however admittedly that was about 15 yrs ago, so it’s no doubt improved since then.
Honestly, I can’t wait to delete all my cPanel servers - I am slowly migrating over and it has been a slow process as so many clients don’t want to change.
Despite the desire to move away from cPanel, there are still a few useful features that I will miss - and I wish Virtualmin could consider adopting.
The Immunify AV is one of them - but yes it’s a proprietary system - though Gemini seems to think it would run as a standalone system, I’ve yet to explore that. I am not entirely sure how that runs (I assume as jailed root) and I don’t know the mechanics of it, but as @shoulders pointed out - it is very nice to have something that does a “macro sweep” occasionally on the server to alert if a malware has been identified. Then you can do something about it.
Gemini suggestions
Your Options on Virtualmin
Option 1: Use ImunifyAV anyway (Standalone Mode)
You can actually run ImunifyAV or Imunify360 on a Virtualmin server using their Standalone installation.
  • It will run in the background, scan your website directories (like /home/), and you can access its separate dashboard via a web browser rather than natively clicking it inside Virtualmin.
  • Note: If you are feeling adventurous, a community-driven open-source module exists on GitHub (developed by IQ Hosting) that allows you to iframe the Standalone Imunify interface directly inside Webmin, but it requires a bit of manual CLI configuration.
Option 2: The Open-Source Virtualmin Alternatives
If you want tools that align better with Virtualmin’s philosophy, most administrators use a combination of these free utilities to achieve the exact same security footprint:
  • LMD (Linux Malware Detect / Maldet): This is the closest open-source equivalent to ImunifyAV. It’s a dedicated malware scanner built specifically for shared hosting environments. You can easily set it up to scan your /home/ directories daily and email you reports.
  • ClamAV: Virtualmin actually has built-in support for ClamAV. It is mostly used for scanning incoming emails, but you can configure a cron job to make it scan your web directories. (Heads up: It can be a bit heavy on CPU/RAM).
  • Fail2Ban: Virtualmin usually prompts you to install this during setup. It protects your server from brute-force attacks on SSH, FTP, and login screens.
  • ModSecurity: You can enable this web application firewall (WAF) directly within Virtualmin’s Apache or Nginx configurations to block exploits in real-time.
