I have a thought for you:
Before:
[code:1]
#!/usr/bin/perl
Delete any orphan php*-cgi processes
package virtual_server;
$main::no_acl_check++;
require ‘./virtual-server-lib.pl’;
&cleanup_php_cgi_processes();
[/code:1]
After:
[code:1]
#!/usr/bin/env perl
use strict;
use Proc::«»Daemon;
Proc::Daemon::Init;
while(1){
sleep(1); # However often you want to cleanup_php_cgi_processes()
[/code:1]
Look ma, no cron! Add to your normal webmin startup routines and enjoy. Extra credit would be to create a pid file in /var/run to start and stop this as you see fit. This way you’re not shoving things into root’s crontab by default. Again, just a thought. :)<br><br>Post edited by: TonyShadwick, at: 2007/11/13 03:54
