Starting httpd2: Syntax error on line 233 of /etc/httpd/conf/httpd2.conf:
Invalid command ‘SuexecUserGroup’, perhaps mis-spelled or defined by a module not included in the server configuration
[[FAILED
This is the error i get when trying to start Apache…
I have absolutely no clue on were to start to fix this…
I saw a possible solution, cant recall what tho…, but that didnt work. It only gave me a unknown command error…
This, I believe gives you all the bits you need, though we don’t have a lot of Mandriva users to give us confirmation of that through real world testing.
I don’t remember if you have to do anything special on Mandriva to enable the suexec module. On most of our systems, installing the module enables it, but it does have to be enabled manually on SUSE, so it might need some extra work on Mandriva, too. As soon as I get caught up, I’ll be doing some building and testing for the newest version of Mandriva and the x86_64 architecture…I should be a bit more familiar with the platform by the time that is done.
I use Mandriva exclusively here. Both 2006 and 2007. If you need anything let me know.
Second in 2006 & 2007 its only apache_mod_* since apache 2.X is the default. Apache 1.X is provide still but you have to call the rpms with the apache1* name instead.
As for anything special for mod_suexec nothing special is needed. Just install it and everything works just fine. There are some mods that will break the httpd -t and cause a warning when testing the conf and vhost files. If you need to know which ones those are let me know.
I also suggest that you join the Mandriva forum at http://forum.club.mandriva.com if you haven’t already and post for Mandriva specific help there. You are a real newbie so I would start there.
When im waking up tomorrow after work i will make sure to read good through all of them…
I still need to get the php mod and perl mod in there so i will try to uprmi (iirc) to do it right.
Again thanks guys.
The apt-get didnt break anything for so far as i can see… Still have to upload some pages and see what happens.
So far i like the webmin / virtualmin / usermin combo.
If i ever reinstall my vds i will for sure use it again… It make smy life so much easyer
