I’m trying to configure a webserver using virtualmin with suexec and fastcgi. I used the following setting s and get the error as seen in error_log. Any ideas?
in httpd.conf:
LoadModule fastcgi_module libexec/mod_fastcgi.so
LoadModule suexec_module libexec/mod_suexec.so
in extra/httpd-fastcgi.conf
<IfModule mod_fastcgi.c>
FastCgiIpcDir /opt/csw/apache2/share/htdocs/suexec/tmp
AddHandler fastcgi-script .fcgi
FastCgiSuexec On
FastCgiConfig -singleThreshold 100 -killInterval 300 -autoUpdate -idle-timeout 240 -pass-header HTTP_AUTHORIZATION
</IfModule>
<Location /php-fastcgi/>
Options +ExecCGI
SetHandler fastcgi-script
</Location>
the vhost file (the real ip is replaced with *****)
<VirtualHost **********:80>
ServerName testserver
DocumentRoot /home/testserver/public_html
ErrorLog /home/testserver/logs/error_log
CustomLog /home/testserver/logs/access_log "combined"
DirectoryIndex index.html index.php
SuexecUserGroup testserver testserver
<Directory /home/testserver/public_html>
Allow from All
</Directory>
ScriptAlias /php-fastcgi/ /opt/csw/apache2/share/htdocs/suexec/testserver/
AddType application/x-httpd-fastphp .php
Action application/x-httpd-fastphp /php-fastcgi/php5-cgi
<Directory /opt/csw/apache2/share/htdocs/suexec/testserver>
Allow from all
</Directory>
LogLevel emerg
</VirtualHost>
Apache is configured this way:
Server version: Apache/2.2.6 (Unix)
Server built: Oct 23 2007 16:48:02
Server’s Module Magic Number: 20051115:5
Server loaded: APR 1.2.11, APR-Util 1.2.10
Compiled using: APR 1.2.11, APR-Util 1.2.10
Architecture: 32-bit
Server MPM: Prefork
threaded: no
forked: yes (variable process count)
Server compiled with…
-D APACHE_MPM_DIR=“server/mpm/prefork”
-D APR_HAS_SENDFILE
-D APR_HAS_MMAP
-D APR_HAVE_IPV6 (IPv4-mapped addresses enabled)
-D APR_USE_FCNTL_SERIALIZE
-D APR_USE_PTHREAD_SERIALIZE
-D SINGLE_LISTEN_UNSERIALIZED_ACCEPT
-D APR_HAS_OTHER_CHILD
-D AP_HAVE_RELIABLE_PIPED_LOGS
-D DYNAMIC_MODULE_LIMIT=128
-D HTTPD_ROOT="/opt/csw/apache2"
-D SUEXEC_BIN="/opt/csw/apache2/sbin/suexec"
-D DEFAULT_PIDLOG="/var/run/httpd.pid"
-D DEFAULT_SCOREBOARD=“logs/apache_runtime_status”
-D DEFAULT_LOCKFILE="/var/run/accept.lock"
-D DEFAULT_ERRORLOG=“logs/error_log”
-D AP_TYPES_CONFIG_FILE=“etc/mime.types”
-D SERVER_CONFIG_FILE=“etc/httpd.conf”
The php5-cgi file:
#!/bin/sh
PHPRC="/opt/csw/php5/lib"
export PHPRC
PHP_FCGI_CHILDREN=8
export PHP_FCGI_CHILDREN
PHP_FCGI_MAX_REQUESTS=500
export PHP_FCGI_MAX_REQUESTS
exec /opt/csw/php5/bin/php-cgi \
-d open_basedir=/home/testserver:/opt/csw/php5/lib:/opt/******/share/htdocs \
-d session.save_path=/home/testserver/tmp \
-d upload_tmp_dir=/home/testserver/tmp
I tried chmod the files so everbody can read them etc but nothing works.
[Wed Jan 09 11:26:55 2008] [notice] suEXEC mechanism enabled (wrapper: /opt/csw/apache2/sbin/suexec)
[Wed Jan 09 11:26:56 2008] [notice] mod_python: Creating 8 session mutexes based on 256 max processes and 0 max threads.
[Wed Jan 09 11:26:56 2008] [notice] mod_python: using mutex_directory /tmp
[Wed Jan 09 11:26:56 2008] [notice] FastCGI: wrapper mechanism enabled (wrapper: /opt/csw/apache2/sbin/suexec)
[Wed Jan 09 11:26:56 2008] [notice] FastCGI: process manager initialized (pid 28368)
[Wed Jan 09 11:26:56 2008] [notice] Digest: generating secret for digest authentication …
[Wed Jan 09 11:26:56 2008] [notice] Digest: done
[Wed Jan 09 11:26:56 2008] [notice] Apache/2.2.6 (Unix) mod_ssl/2.2.6 OpenSSL/0.9.8g mod_fastcgi/2.4.2 DAV/2 SVN/1.4.5 mod_python/3.3.1 Python/2.5.1 configured – resuming normal operations
[Wed Jan 09 11:27:14 2008] [warn] FastCGI: (dynamic) server “/opt/csw/apache2/share/htdocs/suexec/testserver/php5-cgi” (uid 10003, gid 10003) started (pid 28379)
FastCGI: can’t start server “/opt/csw/apache2/share/htdocs/suexec/testserver/php5-cgi” (pid 28379), execle() failed: Permission denied
[Wed Jan 09 11:27:14 2008] [warn] FastCGI: (dynamic) server “/opt/csw/apache2/share/htdocs/suexec/testserver/php5-cgi” (pid 28379) terminated by calling exit with status ‘255’
[Wed Jan 09 11:27:21 2008] [warn] FastCGI: (dynamic) server “/opt/csw/apache2/share/htdocs/suexec/testserver/php5-cgi” (uid 10003, gid 10003) restarted (pid 28381)
FastCGI: can’t start server “/opt/csw/apache2/share/htdocs/suexec/testserver/php5-cgi” (pid 28381), execle() failed: Permission denied
[Wed Jan 09 11:27:21 2008] [warn] FastCGI: (dynamic) server “/opt/csw/apache2/share/htdocs/suexec/testserver/php5-cgi” (pid 28381) terminated by calling exit with status ‘255’
Thanks,
Martijn
