test.domain.com might look like a subserver but i have it as a normal server this is becuase it needed its own stuff as if it was a complete domain. The problem is that the 2 subservers just resolve to domain.com. If i make hostiab1.domain.com the defualt for IP then all the domains will work correctly including the resolving of the hostiab1.domain.com.
The only problem is that none of the other subservers will resolve, they just go to domain.com.
can you explain what you mean with “resolve to domain.com”? It also helps verifying problems if you give the actual domain names instead of dummies. I imagine they’re not secret if you publicly serve them?
Okies, as expected all those domain names “resolve” (as in nameserver lookup) to the same IP address.
Does “secure” imply that you’re using SSL for that site?
If an Apache virtual host does not load but shows the default instead, it usually means that the vhost configuration is somehow wrong. When you go to Webmin -> Servers -> Apache Webserver, which vhosts does it show you and on which ports? Check the address, port, server name and document root there. You might also post a listing of the domain list here, enclosed in tags for better readability.
Yes they all resolve to the same IP this is correct. And yes it will be SSL but at the moment its is not whilst i try to get the subservers working correctly.
I have looked in the apache settings and all websites are confgigured to use port 80 and the correct ip address. I have tried removing the subserver and restarting apache multiple times and it will still not work.
The hosts list looks okay, yeah. It’s quite odd, since whatever you set as “default server for this IP” should have no influence except when you request an unknown hostname.
Do you have any forwardings, redirections, proxying or similar in place? Can you check the Apache logfiles? Maybe those’ll give you some hints. Next step would be taking a look at the Apache config files.
I have enabled Website matches all sub-domains? on all the domains, but when i disable this it dosent seem to fix anythink.
The only errors in the apache logfiles is the ones relating to there being no favicon.ico or robots.txt.
There are no forwardings redirections or proxying being used which i no off. If there is then virtualmin has setup these its self.
I have gone through all the domains and cant see anythink.
Well, the “matches all sub-domains” definitely was a problem, since it will wildcard all subdomains to the one where you set that.
You may want to double-check that the feature is really turned off everywhere, that Apache is restarted and there’s no leftovers of that setting in the Apache config file.
Let me know if you can’t figure it out, then I’ll do some experiments what this feature effects in the config file, I haven’t used it myself so far.
I have no disabled the matchesall sub-servers, i also checked through the DNS for left entries. And went through the apache entrys for each server. I removed all teh aliasserver *.domain.com.
I also noticed that there where a bunch of alias server lines with no text after them just blank. I remoebed these and saved it, restarted apache didnt work, restart server didnt work.
Okay… I’m afraid I’m a bit out of ideas here, short of taking a look at your Apache config files myself. I’m somewhat doubtful though that you’d want to give me the necessary access to your system.
Thank you very much for your help “Locutus”, i have now managed to fix this problem. I dont no exactly what how i fixed it all i no is that i reapplied the “match all subservers rule” then manualy deleted it from the dns and httpd.conf and then it worked.
Instead of making a new post i will post the problem i am having now. My website runs on ip address 94.76.201.162, is it possible to have a subserver run on IP 94.76.201.161, i have made the subserver and specified the IP, it has made the apache settings and dns settings for it but it dosent work.
As for your new problem: What exactly “does not work”? Can you elaborate please what you did and what happened? In general it’s sure possible to operate a sub-server on a different IP address.
Actually, for me the IP address with .161 in the end, and secure.shanerutter.co.uk show the same thing: a directory index with “awstats_icon” and “icon” subdirectories (probably links), while “shanerutter.co.uk” shows a web page with “Shane Rutter - PHP Programmer”.
So, from my end, it seems to be working as intended.
Not yet updated DNS servers is a possible reason, yeah. Every entry has a time-to-live. I tend to set those to 30 seconds when I’m in an experimentation phase.
